Sway bar endlinks busted
Old Jan 28, 2019 | 06:17 PM
Savage997's Avatar
5 Year Member
Savage997 is infamous around these parts
Newbie here, was putting stock wheels on my 997.1 to store car for winter and noticed driver side sway bar endlink was busted, don’t know too much about everything done to car because I bought it this way, I know the car has bilstein coil overs with pasm, and it looks like it has aftermarket sway bars, my question for you guys is do u have to use aftermarket endlinks to work with a lowered setup? Do they have to be shorter or does stock links work fine?
Old Jan 29, 2019 | 09:10 AM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
Old Jan 29, 2019 | 09:40 AM
lliejk's Avatar
5 Year Member
lliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud of
There was a post about this a while ago. Basically there are updated links from Bilstein that are bent, not straight to address this issue. Not sure how you would go about getting them, but contacting Bilstein may be worthwhile.
Check this link (and the ones it mentions):
https://www.6speedonline.com/forums/...k-install.html
Ed
Old Jan 30, 2019 | 12:21 PM
nzskater's Avatar
nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !
To confirm those look like after market links, likely those that came with the Bilstein shocks, and as mentioned above they should be replaced. I'd ask Bilstein for their updated version at no cost.
Old Feb 8, 2019 | 07:42 PM
Savage997's Avatar
5 Year Member
Bilstein couldn’t get me replacements, also looks like other drop link was cut and modified as well, so I went with tarett engineering links from rennline, now she’s all fixed ready for spring
zoomzoommo
Jan 11, 2010 06:21 PM
himself
Mar 20, 2009 09:27 AM
Aug 24, 2008 12:47 PM
jrgatfh
Apr 24, 2007 05:21 AM
