Did this shop damage my car?
Old Feb 11, 2021 | 05:45 PM
paymon19's Avatar
paymon19 is infamous around these parts
I have a 997 turbo tiptronic only mod is a Gmg exhaust with cats. Recently the drivers side radiator was leaking so I took it in for a replacement. The shop installed an OEM radiator and they held it under pressure overnight and they said it had a leak. I th ought this was fishy. They then said they would get an actual Porsche radiator brand new and install it and they did that. In total my car was there for 1.5 weeks.
the shop is also an APR dealer so I had them install their tune. They also replaced a drive belt. I picked up the car today and noticed it has an airbag light. I'm guessing they may have damaged a sensor in the front end when they removed the bumper? Also when driving the car feels slower than stock. I didn't go all out due to weather but in sport mode it was only building 2 psi at 4K rpms.
I am extremely angry that this shop would charge me several thousand dollars and return my car to me in this shape. They are closed currently as it's late but I have left them a very angry message
Old Feb 11, 2021 | 10:32 PM
goducks's Avatar
goducks has a spectacular aura aboutgoducks has a spectacular aura aboutgoducks has a spectacular aura about
Did the shop damage your car? Nothing sounds like it can’t be corrected quickly.
Does an APR tune package include an access port that allows you to remap or customize the tune? I have a Cobb tune and I can change the settings through the OBD ll port. If an access port is not provided, then the tune may not have been installed properly, and will need attention from your shop.
The airbag light doesn’t sound like a huge problem, but is definitely annoying. The shop should make that right. I would be somewhat annoyed with a shop that takes over a week to install a radiator. I had my shop replace my clutch and pin my coolant pipes, which requires the engine to be removed, in significantly less time.
Old Feb 12, 2021 | 11:57 AM
bmw_e30's Avatar
bmw_e30 is infamous around these parts
sounds like you need to talk to the shop asap and get it sorted out
z06801
Apr 27, 2015 04:23 PM
richard181
May 27, 2014 07:48 AM
gottspd
Dec 20, 2013 01:30 PM
erubin
Mid-Atlantic
14
Sep 5, 2008 12:39 PM
dzy
Mini Cooper
30
Jan 18, 2008 05:25 PM
