997.1 turbo oil and water feed lines help
Hi there all. Could anyone recommend some use sources I can contact who may have oil and water feed lines into and out of the turbos please? Porsche are out of stock and my build needs finished.
thanks 👍
thanks 👍
All of them? Someone just did a Cyl 1-3 Coolant line (that was not being produced when I did my engine drop over a year ago) and found one.
I was able to find the other lines I needed at that time (except for Cyl 1-3 coolant). Make sure you have the updated part number. For instance the coolant line on Cyl 4-6 is listed in the KAT as 997 106 076 73 997 106 076 73 but the replacement is 997 106 076 77 997 106 076 77.
Suncoast has only 1 of them in stock:
https://www.sunsetporscheparts.com/oem-parts/porsche-coolant-pipe-99710607677
Likewise the breather line on that side 997 107 240 74 997 107 240 74 is actually 997 107 240 76 997 107 240 76.
Also available at Suncoast:
https://www.sunsetporscheparts.com/oem-parts/porsche-vent-pipe-99710724076
On the other side (Cyl 1-3), coolant line 997 106 075 74 997 106 075 74 is now 997 106 075 76 997 106 075 76. Sunset says special order, but other dealers and Pelican act like they are available, but you should check to be sure. Same with the breather line 997 107 239 76 997 107 239 76 which is now 997 107 239 77 997 107 239 77 and also shows special order from Suncoast.
Unless you all steel lines are rusted out, you can just get new O rings for them. I did not replace mine, just the O rings.
Ed
Ed
jordonmusser
Jul 21, 2015 02:02 PM
