Unsolvable ABS/PSM light
Old May 12, 2024 | 06:08 PM
HashishJackson's Avatar
HashishJackson is infamous around these parts
This started as an intermittent issue, and was resolved with a brake light switch and or wheels speed sensor, it had a run of 6 months before it’s returned. It’s immediately on during start up and this time it doesn’t go away
code is P0503
list of items I’ve replaced:
3x - front left wheel speed sensor
3x - brake light switch
1x - MAF sensors both sides
1x - Air filter
1x - Battery
Durametric is reading signal/revolutions from all 4 corners
Any recommendations on what to do next? I took it to the dealer and paid $300 for them to tell me it’s the wheel speed sensor 🤦‍♂️ . I’m dreading the cost of a shop to diagnose….
Hoping someone here has further knowledge, Tnx for reading
Old May 16, 2024 | 12:09 PM
993Godspeed's Avatar
993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !
Are all wheel speed sensors moving/logging at the same time? Is there any spike when you log it in durametric? They should all be moving at the same rate and there should not be any spikes, if there are spikes, check which wheel speed sensor is not reading correctly,
tonyhw206
Dec 18, 2023 01:32 AM
phsarkiri
Bentley
Nov 8, 2021 09:51 PM
ET911
Feb 13, 2021 07:48 PM
vramani
Southwest
14
Jan 16, 2009 11:23 AM
