Couple of 997 TT questions
Old May 11, 2006 | 10:55 PM
SHANKENFELTER's Avatar
SHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud of
Is the standard Big Red Brakes BIgger than the 996TT ones?
Is the 997TT wider than the 996TT?
Old May 11, 2006 | 11:22 PM
Porscheboy16's Avatar
Porscheboy16 is a glorious beacon of lightPorscheboy16 is a glorious beacon of lightPorscheboy16 is a glorious beacon of lightPorscheboy16 is a glorious beacon of lightPorscheboy16 is a glorious beacon of lightPorscheboy16 is a glorious beacon of light
I believe the 997TT is wider than the 996TT.
Old May 12, 2006 | 07:05 AM
BD 997's Avatar
BD 997 is infamous around these parts
It is wider by a little over an inch. And the red brakes on the 997tt are the same size as the PCCB. Only the rotors on the new PCCBs are bigger (380mm vs 350mm)
Old May 12, 2006 | 09:02 AM
SRW's Avatar
SRW
SRW has a reputation beyond reputeSRW has a reputation beyond reputeSRW has a reputation beyond reputeSRW has a reputation beyond reputeSRW has a reputation beyond reputeSRW has a reputation beyond reputeSRW has a reputation beyond reputeSRW has a reputation beyond reputeSRW has a reputation beyond reputeSRW has a reputation beyond reputeSRW has a reputation beyond repute
996 TT Front Brake = 4-piston 330mm discs
997 TT Front Brake = 6-piston 350mm discs
997 TT Front Brake PCCB = 6-piston 380mm discs (CGT)
http://www.porsche.com/uk/models/911...detail/safety/
Old May 12, 2006 | 10:04 AM
BD 997's Avatar
996TT PCCB = 6-piston 350mm
Old May 12, 2006 | 11:04 AM
B7R's Avatar
B7R
B7R has a spectacular aura aboutB7R has a spectacular aura aboutB7R has a spectacular aura about
That's correct BD997 and those are the same size on the 997 Turbo
COBB Tuning
Jan 1, 2025 09:02 AM
mlife2878
Aug 26, 2015 07:02 PM
pwdrhound
Aug 23, 2015 07:36 PM
Aug 21, 2015 09:56 AM
