Smokey Places
Old Sep 23, 2006 | 08:09 AM
richboy's Avatar
richboy is infamous around these parts
Smokey Places
Every now and then when I start my 997tt I get a cloud of smoke. Any one else getting this?
Old Sep 23, 2006 | 09:35 AM
TT Surgeon's Avatar
Be sure you are letting the turbos cool down a minute or so before shutting the car off.
Old Sep 23, 2006 | 11:00 AM
Mussel Kar's Avatar
Mussel Kar is a jewel in the roughMussel Kar is a jewel in the roughMussel Kar is a jewel in the rough
Once in a while, that's all. I noticed it when I backed the car out to wash it. It did not do it when I put it back inside.
Old Sep 23, 2006 | 03:43 PM
gmoney's Avatar
997 turbos are water cooled units so idling after regular driving is not necessary unlike oil cooled turbo units where you must to prevent oil coking in the turbo jackets and lines.
Old Sep 23, 2006 | 04:23 PM
ECB's Avatar
ECB
ECB is infamous around these parts
...maybe I'm off base here...but
Are you confusing water cooling of the engine and turbo?
Last time I checked, water will evaporate instantly when introduced to high heat...unless you greatly increase the partial pressure in the system.
pv=nrt.
Old Sep 23, 2006 | 05:33 PM
gmoney's Avatar
No, most new turbos on cars are water cooled where bigger, aftermarket ones along with ones of yesterday were oil coiled. Forget engines for the moment.
oil cooled turbos spawned the turbo timer craze (or sitting in your car idling for 1-2 minutes) as oil was coking up in the lines when the owner shut the engine off after running it hard. Oil would essentially cook and choke up the lines or turbo damaging it over time.
Water cooled turbos work just like the engine where water (and coolant) do the job. As water wont coke up the necessity to idle is reduced and would not likely be the cause of smokey startups.
Old Sep 23, 2006 | 08:17 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
Also, turbos aside, its a flat engine...oil pools in the cylinders when shut off and is burnt immediately on start up... completely normal. Some do it more than others, also depends on how the rings are aligned on the pistons when the car is shut off, as ring gaps closer to the bottom will allow slightly more oil to sneak by, granted we're talkin drops here, more oil being a couple more drops at the most.
Old Sep 23, 2006 | 08:19 PM
HotRodGuy's Avatar
could it just have been condensation from the exhaust pipes after you washed it?
Old Sep 23, 2006 | 09:17 PM
DJ's Avatar
DJ
I always get that with the 996 TT's
Old Sep 25, 2006 | 09:12 PM
911-996's Avatar
911-996 is infamous around these parts
As porschespeeddem said
Its a flat engine thing, My Boxster S does it all the time on cold starts.
Old Sep 25, 2006 | 09:46 PM
PorschePhd's Avatar
997TT uses oil cooled turbos. Porsche only used a water cooled turbo on the 931, 937 and the 951. Everything else including the new ones are oil cooled. It has nothing to do with old new or other. All HO 6 cylinders smoke on start up every now and then. Run them a quart low an you will not normally see this...Continue to idle down for at least a minute as we have always done. Some smoke is normal.
Old Sep 25, 2006 | 09:47 PM
And 955...(CayenneTT)
Old Sep 25, 2006 | 09:48 PM
PorschePhd's Avatar
oops, sorry. I was thinking sports car not SUV.
Old Sep 25, 2006 | 09:51 PM
Very true there, not many people think turbos when they think of SUV's in general, excellent combo though..
Old Sep 25, 2006 | 09:53 PM
ECB's Avatar
ECB
Thats what I thought...I thought I was going crazy there. Water cooling 996/7TT turbos??
Yeah...I always idle mine down too - especially now with these F600s...
