What is the highest speed for 997TT
Old Sep 23, 2006 | 10:57 PM
cayenne_ksa's Avatar
cayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond repute
Yesterday I was driving my TT there wasn't a lot of cars in the highway I went over 320km/h (200 mile/h) but I couldn't get over 325km it seems that it has been adjusted to not exceed 325km/h. When I reached 325km the power cut off for a while then comeback but it was amazing the car has no problem to go faster.
Old Sep 23, 2006 | 11:30 PM
atomic80's Avatar
From what I understand, the Turbo has been limited to 193 mph (310.59 kph) apparently because of tire limitations. Heck, the GT3 has the same top speed too. You probably also know that the speedo doesn't show the true speed when moving especially at those speeds. Almost all speedos are artificially higher than the true speed. I have no idea why they do it like that.
I wonder if there's a software upgrade that will defeat the speed limiter.
Old Sep 24, 2006 | 12:46 AM
Cognac's Avatar
Cognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant future
you broke your own record!
did you take video this time?
Old Sep 24, 2006 | 12:05 PM
xandi911's Avatar
xandi911 is infamous around these parts
CONGRATSS! videos for us!
Old Sep 24, 2006 | 01:51 PM
Dabum's Avatar
Dabum is infamous around these parts
Thats nuts, be careful!
Old Sep 25, 2006 | 10:53 PM
.:Raul's Avatar
.:Raul is a splendid one to behold.:Raul is a splendid one to behold.:Raul is a splendid one to behold.:Raul is a splendid one to behold.:Raul is a splendid one to behold.:Raul is a splendid one to behold.:Raul is a splendid one to behold
wow thats amazing
Old Sep 25, 2006 | 11:14 PM
raiyu's Avatar
raiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to behold
Not sure if its 100% but I think its because of regulations, if the speedometer showed a speed slower than the car was actually going they would be in hot water legally, so to avoid it, especially as speed increases, you get a bit of a margin of error so that legally they dont get in trouble.
Old Sep 26, 2006 | 09:37 AM
Vudu's Avatar
Vudu is infamous around these parts
I understand that all manufacturers overstate their speedometers whether for legal reasons or not, but I read somewhere that Porsche speedometers are one of the most accurate.
Cayenne_ksa: if your speedometer was showing 325kph, I believe your real-time speed was maybe only a few kms less than that (but definitely over 320kph).
Hey, mabrook 3ala sayartik wa mubarak 3alaik fishahar! min oukhouk fil Bahrain!
We should meet up somewhere when my TT arrives and tear up the roads a little
Old Sep 26, 2006 | 09:43 AM
Vudu's Avatar
Question Need for Speeeeed!
This goes out to the tuners following this thread:
Is there a way to remove the speed restriction on the 997TT? I know it's because of tire restraints, but assuming you put on some top speed rubber and play with the ECU would you be able to go faster??
Old Sep 28, 2006 | 03:03 PM
Octanemia's Avatar
Octanemia is infamous around these parts
where could you drive that fast in a small city like Al-Koubar??
BTW, I saw you couple of times in Cournaish,, also with the oringe Gallardo. It's a shame we don't get to see alot of supercars here. There are couple of GT2s and 2 Gallardos and 2 Z06.
Old Sep 28, 2006 | 05:01 PM
gmoney's Avatar
What was the RPM in top gear for that speed? Had no idea it is limited by computer vs. drag / power.
Old Oct 1, 2006 | 02:52 AM
I took video like last time but I don't know what's wrong with my cellphone it didn't save the video . I was going to throw it away
Old Oct 1, 2006 | 03:00 AM
I'll be really happy to meet you and hang out together, don't know if we can track our cars in the circuit I heared that it's posible to rent it ?
Old Oct 1, 2006 | 03:02 AM
Where you from Octanemia
Old Oct 2, 2006 | 10:19 PM
that's why the power cut off the RPM reached the highest in the red area i think I can reach more by some programe
