Sliding while Cornering
Old Feb 22, 2007 | 11:31 PM
2K7997TT's Avatar
2K7997TT is a jewel in the rough2K7997TT is a jewel in the rough2K7997TT is a jewel in the rough
Today for the first time the tires spun and the car slid (unintentionally) while cornering on three occasions.
Each time I was turning pretty slowly.
In second gear.
Temperature 80 degrees and Road Dry.
Stock Tires.
Stage III System (GIAC, Headers, FS Exhaust).
PSM on.
I was accelerating, but definitely not punching it.
Anyone else experience anything similar??
While stock I could really gun it around a corner without problems.
I have a hard time believing the extra 120 hp or so is responsible for freeing up the tires and sliding.
Old Feb 22, 2007 | 11:33 PM
unique's Avatar
unique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud of
In second gear.
Stock Tires.
PSM on.
if theres a way u can get that on video........ YOU WILL BE MY HERO
Old Feb 22, 2007 | 11:34 PM
unique's Avatar
ohh and with a extra 120HP you will get alot of wheel spin
Old Feb 23, 2007 | 03:03 AM
mishref's Avatar
mishref is infamous around these parts
My car usually slides due to this:
1. Something on the road.
2. Worn out tires.
3. Cold Tires.
4. PSM off + pushing it
Old Feb 23, 2007 | 05:23 PM
ANUBIS's Avatar
ANUBIS is infamous around these parts
thats very strange. if u're not pushing it shoudn't happen. did u mod the suspension ?
Old Feb 24, 2007 | 09:16 AM
raclaims's Avatar
raclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to behold
Been stuck to the road since I got it...even in snowy, icy conditions...
Used to happen to me in my old car when the tires were going a little bald...which happened pretty damn fast.
Old Feb 24, 2007 | 06:14 PM
Schuepbach's Avatar
Schuepbach is infamous around these parts
In second gear.
Stock Tires.
PSM on.
how did you approach the turn? were u still braking after turn in? if you were braking while turning in, alot of the weight is pushed forward and off the rear wheels, that coupled with an extra 120 horsepower is sure to cause the wheels to spin a bit
even with that aside the extra 120 hp will def help with traction loss
Old Feb 24, 2007 | 06:35 PM
2K7997TT's Avatar
No suspension mods.
Yes, I was braking going into the corner.
I was permanently stuck to the asphalt (pre-mod).
Old Mar 2, 2007 | 11:00 PM
Jak-GT2's Avatar
Jak-GT2 is infamous around these partsJak-GT2 is infamous around these parts
even with my C4S which only has 355hp, the tires do break loose at corners if I punch it..
calexand
Nov 5, 2015 01:05 PM
s6spd
Oct 6, 2015 08:20 PM
alpha motoring
Oct 2, 2015 12:04 PM
Ronny-
Oct 1, 2015 10:40 AM
