Tech Art PASM Coil Over Suspension Mini-Review
Old May 11, 2007 | 12:26 PM
sharkster's Avatar
Hey guys, so we're now done with the installation of the PASM Coil Over kit on Fred's 997TT and I just got back from a road test so I can give you guys my take on it. We've done spring kits on these cars as well so I've got some reference points that aren't just stock either.
The kit comes with all the lines that plug into your PASM suspension as well as more beefy drop links in the front. It's actually pre-assembled so you don't need to do any tinkering (you obviously re-use your camber plates). They set it to a "recommended" height which is about an inch lower although Fred wanted to match his GT3RS ride height so we lowered it a little more. Expect a full day for installation and it's important that you route the front PASM/lines correctly and "out of the way" from any danger of fraying etc...
Once lowered and on the road I started out in "normal" mode. It felt very much akin to stock and if anything rode "softer" over some of the local bumpy roads. It was quiet, very settled and compliant. It took the bumps even better than the stock suspension and there was no bounciness like you'd get with springs. I'd go as far to say that it feels like some of the more luxurious electronically controlled suspension set ups found on the higher-end 4-door Mercedes. Taking turns in comparison to stock it certainly swayed less and felt more planted. The alignment needs some tuning obviously but I felt more comfortable taking turns in the Normal mode than with the stock suspension in sport mode. It's a _very_ nice ride indeed and I could see most people using the most 90% of the time. I took the car on some really shoddy roads (we can be thankful that our tax dollars are hard at work here) I'm not saying your coffee cup is "safe" but it's a lot lot better than stock.
Pushing the sport mode button made things really different. It'd go over the bumps and you could really feel them this time but again it was much more compliant and had no bounciness or bump-steer characteristics. I could really dive into those turns and I would really like to see this at the track where the road-surface is much more suitable and flat to let the shocks do their thing. It's quite aggressive and if I had to compare it to say a 996TT PSS9 kit, in my mind, the settings would be about 2/1. I'm told by tech art that they will be entering their car into the European Tuner shoot out with this very same kit and although it's no double-adjustable Moton ClubSport (it doesn't have the adjustability either obviously) it's great to finally have a real coil over system that was/is designed for the owner that wants to keep his/her PASM functional (TASM - hehe?). Most people won't adjust things manually because they don't have a lift etc... so this set up sure makes it easier to switch from normal to aggressive modes going to and from the track for example.
In a nut-shell (and this will obviously please the other three guys on assembly line heh) this is the _right_ way to lower the car. It's got enough adjustability for guys with stock bumpers or aftermarket bumpers and unlike spring kits you really do get a much happier handling car.
Old May 11, 2007 | 12:29 PM
sharkster's Avatar
here's what she looks like lowered and sans that "nasty" wheel gap
Old May 11, 2007 | 02:40 PM
DimNSlow's Avatar
DimNSlow has a spectacular aura aboutDimNSlow has a spectacular aura aboutDimNSlow has a spectacular aura about
Looks amazing- Much better. Great work Sharky, I'm sure Fred will love it!
Old May 11, 2007 | 02:45 PM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond repute
Great stuff, as always. Nice write up.
Old May 11, 2007 | 03:15 PM
fredttx50's Avatar
fredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond repute
Much much much better!! Now I'll have a tougher time getting my car in my garage
We'll take Videos tomorrow morning. Make sure to call Robert so he can wash my rims too
Old May 11, 2007 | 03:18 PM
Itzkirb's Avatar
wow...really niceeee
Old May 11, 2007 | 03:19 PM
Redlinerobert's Avatar
Senior Member
Redlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond repute
si senor.
Old May 11, 2007 | 03:55 PM
sharkster's Avatar
Originally Posted by Redlinerobert
si senor.
Manzanita Sol on me!
mogz's Avatar
mogz is infamous around these parts
Oh my... the best TT so far?
Old May 11, 2007 | 09:55 PM
ThisFlyGuy's Avatar
ThisFlyGuy is a jewel in the roughThisFlyGuy is a jewel in the roughThisFlyGuy is a jewel in the roughThisFlyGuy is a jewel in the rough
wow, looks great fred
Old May 12, 2007 | 12:51 AM
alex911s's Avatar
alex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond repute
wow i like it...
Fred,
I need a new car
Old May 12, 2007 | 02:08 AM
unique's Avatar
unique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud of
thanks for the write up.... i am definately gona do this when my car arrives
Old May 12, 2007 | 06:48 AM
bobk's Avatar
bobk is infamous around these parts
Thanks for the write up. Do you know if the lower ride height results in adequate travel remaining to keep the suspension off of the stops. This was what kept me from pss9's on my 996tt. Losing composure in a fast bump filled corner was too much to accept for improved ride height with the bilsteins.
Thanks again
Old May 12, 2007 | 08:43 AM
TT Surgeon's Avatar
^That was always my issue with the pss9's as well. However, this looks like a well thought out setup, until Porsche motorsports releases the X73 (this fall?) for the 997TT this is the way to go.
Old May 12, 2007 | 10:22 AM
sharkster's Avatar
Thanks again
Sorry if I wasn't clear about this but if you lower the car to GT3RS type levels then no there is no issue with riding on the bump stops. It's set up to go lower than the PSS9s on the 996TT etc... I had no bump steer etc...
