TT Cab artilce and test......
Old Jun 22, 2007 | 04:14 PM
DJ's Avatar
DJ
<TABLE width="100%"><TBODY><TR><TD colSpan=2>So the Turbo Coupe gets the predictable cabrio chop then…
</TD></TR><TR><TD>Spot on. And at £106,180, this turbocharged, open-top, tech-fest is the flagship of today’s range. The only 911 topping £100k comes with a turbocharged flat six engine producing 480bhp, all-wheel drive, active suspension and every conceivable goodie: DVD navigation, leather comfort seats, Bose sound system.
But there’s one crucial thing Porsche has forgotten to make standard – an eye-test before the keys are handed over. Believe you me, the way this thing piles on speed, you need perfect long-range vision to pick out upcoming obstacles. Blink and by the time your eyes readjust, you’ll be bearing down on hairpins or Smart cars or oblivious wildlife. It makes for an exhilarating drive… </TD></TR></TBODY></TABLE>
<TABLE width="100%"><TBODY><TR><TD colSpan=2>How come it’s so quick?
</TD></TR><TR><TD>The 3.6-litre flat six is breathed on by two turbochargers with variable turbine geometry, to optimise boost pressure. It’s only now, with the third generation 911 Turbo cabrio, that Porsche could implement variable vanes that can resist operating temperatures up to 1000-degrees in the exhaust flow. The benefit is a consant rush of torque, with a 457lb ft punch delivered consistently from 1950 to 5000 revs.
Tick the one obligatory option box for the £1015 Sports Chrono Pack and there’s a turbocharger overboost function, which serves up an additional 0.2 bar and 44lb ft, and shaves a few extra tenths of the already eye-boggling in-gear acceleration. Zero to 62mph takes 4.0sec flat; don’t lift for another 8.0sec and you’ll hit 124mph or 200kmh. Top speed is 192mph.</TD></TR></TBODY></TABLE>
<TABLE width="100%"><TBODY><TR><TD colSpan=2>What does all this acceleration feel like?
</TD></TR><TR><TD>A bit ludicrous, to be honest. Engage gear, prod throttle, feel like you’ve been launched by a mediaeval catapault. Engage next gear, charge ballistically forward again. This is a fantastic engine, which serves up a relentless surge of torque. Its effortless nature resembles a diesel’s, though with a howling, metallic turbocharged six soundtrack.
The digital speedo keeps throwing up increasingly preposterous (and illegal) numbers, as the scenery blurs and you focus on keeping the Turbo cabrio on that tongue of tarmac snaking ahead of you. It’s reminiscent of a brutal and simplistic arcade game, rather than the nimble, engaging drive of more humble 911s. </TD></TR></TBODY></TABLE>
<TABLE width="100%"><TBODY><TR><TD colSpan=2>Really? Has Porsche cocked it up?
</TD></TR><TR><TD>Well, the steering definitely doesn’t feel as direct and alive as on a Carrera S. Maybe it’s due to the extra weight of the all-wheel drive, bracing and electric roof, which bulks the Turbo cabrio up to 1665kg (though still 10kg less than the 993 equivalent). The wheel still jigs in your palms, and beautifully conveys every score and undulation in the road surface.
Appropriately, throttle response is lightning fast, although you’ll be stretching into the passenger footwell to connect with the offset pedal. Stomp on the brakes and all that speed is calmly hosed away by six-piston callipers clamping 350mm iron discs (which can be upgraded to carbon ceramic composites). This stable and powerful deceleration is almost as impressive as the acceleration, to be honest.
Cornering is equally other-worldly: keep your toe down, and the four-wheel drive system and active rear wing sucks the cabrio through bends. No drama, just dogged grip and another straight opened up to exploit. Indeed, Porsche claims this car is the world’s first convertible whose aerodynamics generate downforce on the rear axle. </TD></TR></TBODY></TABLE>
Old Jun 22, 2007 | 04:15 PM
DJ's Avatar
DJ
<TABLE width="100%"><TBODY><TR><TD colSpan=2>Now we’re talking. Which gearbox should I (virtually) spec ?
</TD></TR><TR><TD>The Tiptronic S automatic is quicker, shaving two-tenths off the manual’s 0-62mph sprint for a 3.8sec blast. Although journalists are hassling Porsche’s engineers for a double-clutch system in keeping with its motorsport history, the current ‘box has Audi’s S-tronic system licked. The changes feel quicker and smoother, and you don’t have to lift as the next cog melds into place.
But it’s not perfect. In automatic mode it continually seeks higher gears, with an eye on fuel economy (combined consumption is 20.6mpg for the five-speed auto, 21.9mpg for the six-speed manual). It also changes up for you, if you’re hanging around the redline. And the ‘paddles’ are a joke. They are awkwardly positioned buttons on the face of the wheel, which toggle up and down – assuming you manage to hit their g-spot.
Unless you’re continually caught in traffic, go for the manual. It’s trad Porsche – precise and with a springy action that’s like twanging on Action Man’s elasticated leg.
<TABLE width="100%"><TBODY><TR><TD colSpan=2>So it can do quick. Can it do slow?
</TD></TR><TR><TD>Impeccably. This is a supercar that you can drive like a supermini, should you be feeling sensible. Mooch around at urban speeds and there’s not a grumble from the understressed six. Don’t expect the ride on the 19-inch rims to be anything other than jarring, though – naturally the body must be mercilessly tied down, to realise the Turbo Cabrio’s extreme performance potential.
Hit the Sport button to firm up the spring and damper rates and potholes feel like landmines. But this is the only way to travel, and the ride gets more fluent the faster you go. ‘I was speeding under orders from my chiropractor, officer…’</TD></TR></TBODY></TABLE>
Old Jun 22, 2007 | 04:16 PM
DJ's Avatar
DJ
<TABLE width="100%"><TBODY><TR><TD colSpan=2>Can you make yourself heard?
</TD></TR><TR><TD>Up to an (illegal) point. Thanks to the standard wind deflector and with the windows raised, you’ll be able to chat comfortably at motorway speeds. And watching the roof do its thing is mesmerising: the rear panel slides backwards and the Z-shaped section glides out, like a snake under the spell of a charmer. It’s a slippery shape too – the convertible has a 0.31Cd drag figure, and is just as aerodynamic as the coupe with the roof up.
There’s the odd wiggle from the rear-view mirror but the Turbo Cabrio feels very solid. And the seats are great – comfy but so supportive and figure-hugging they could be standard fit on the space shuttle. The dashboard architecture is looking fussy these days. Long rectangle here, arc for an airbag there, quadrilateral glovebox yonder: in tan leather, it looks the contents of a milk chocolate box have melted and fused together</TD></TR></TBODY></TABLE>
DJ's Avatar
DJ
<TABLE width="100%"><TBODY><TR><TD colSpan=2>Verdict
</TD></TR><TR><TD>The 911 Turbo Cabrio is a technical triumph. The way it corners, accelerates and brakes defies physics. And compared with many supercars with similar ballistic performance, it’s good value. But…
You may think this sounds churlish, but its performance is too effortless, too relentless, too soul-less. It’s like the machines have taken over, and rendered the driver all but redundant. I’d go for the lighter, nimbler, rear-drive-only GT3 coupe instead, and invest the £30k saving in sunbeds, if you really must have that tan.
Source :http://www.carmagazine.co.uk/first_d...sid=796&page=1
Old Jun 22, 2007 | 05:31 PM
Octanemia's Avatar
Octanemia is infamous around these parts
great,
thanks DJ.
Old Jun 23, 2007 | 07:39 AM
jamie's Avatar
Yummy!!!!!!
Old Jun 23, 2007 | 08:18 AM
Est8esq's Avatar
Est8esq is infamous around these partsEst8esq is infamous around these parts
I know beauty is in the eye of the beholder, but I just don't like the sterile look of the 997. It reminds me of the first years of the 996, '00 & '01.
I've thought about upgrading myself and getting myself on the list, but there's just not enough of a difference, not to mention the better lines of the 996 (obvioulsy, IMO).
My brother is hankering for a turbo cab and is torn between this vs. a pre-owned '05 like mine. You can get screaming deals right now, low mileage vehicles, put a few bucks in a programmer and a modest bodykit and have everybit a car as the new cab?
I'm sitting in an eye surgeon's waiting room while my wife gets her laser surgery, killing time and wanted to just proffer my $.02.
Old Jun 23, 2007 | 01:37 PM
MeanMachine's Avatar
Meteor / Sand is looking superb on the Cabriolet.
Old Jun 24, 2007 | 05:56 AM
alin2's Avatar
alin2 has much to be proud ofalin2 has much to be proud ofalin2 has much to be proud ofalin2 has much to be proud ofalin2 has much to be proud ofalin2 has much to be proud ofalin2 has much to be proud ofalin2 has much to be proud ofalin2 has much to be proud ofalin2 has much to be proud of
So this is the new malachite green?
Old Jun 24, 2007 | 07:50 AM
Could be, at first I though it was Meteor but then I noticed it has a slight neutral green to it.
Old Jun 24, 2007 | 08:00 AM
bbywu's Avatar
Porsche's decision to implement the teardrop headlights on the 996 created imbalance on the front end. While the 997 may not have been a radical redesign of the 996, I think of it more as an evolution. Plus...the interior is infinately better.
Old Jun 24, 2007 | 11:58 AM
terrence's Avatar
terrence is a jewel in the roughterrence is a jewel in the roughterrence is a jewel in the rough
British mags never like convertibles, at least not over their coupe counterparts. A convertible is not about tanning, but about hearing all the engine and exhaust from the outside, the feeling of wind in the hair, the greater sensation of speed, the blue skies or starry night skies, etc....
Old Jun 25, 2007 | 08:38 PM
Sonny's Avatar
Sonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud of
Me don't liky either!!
Old Jun 28, 2007 | 04:59 PM
glpdx's Avatar
glpdx is infamous around these parts
I agree with Est8esq. When I bought my 996TT S Cab, I put a deposit on a 997TT Cab and was first on the list. I eventually pulled the deposit because I just couldn't get in to the new look. The 997TT seems too busy and more of a Gran Toursimo, like a Austin Martin or Maseratti. The 996TT seems more sporty, especially the interior. I admit, the 997 interior is finished off better, but it looks like it belongs in a luxury sedan, not a sports car. For instance, a Ferrari has a classic 'sports car' interior with the rounded vents and no center console.
The 996TT, full stock and stock ride height leaves something to be desired. On the other hand, a 996TT with a little aftermarket trim, lowered with some agressive wheels is absolutely georgeous. The fully stock 997TT looks better than a stock 996TT, but even a 'fixed up' 997TT can't match the beautiful and sporty look of a 'fixed up' 996TT.
The 997TT definately has some nice new features, but nothing that is absolutely necessary. I've given this a lot of thought. The 996TT Cabriolet has the perfect balance of features, comfort, performance and looks and I don't have any intention of replacing it... ever.
JWrightPNH
Nov 9, 2015 03:40 PM
JWrightPNH
Oct 1, 2015 01:21 PM
larryg
Sep 28, 2015 11:16 PM
lgl314
Sep 28, 2015 04:17 PM
