19" 315 Rear - Do not work
Old Jul 24, 2007 | 08:37 PM
shashi30004's Avatar
shashi30004 has a spectacular aura aboutshashi30004 has a spectacular aura about
FYI
For anyone considering to change tire sizes on the car.
I have the 19" Champion Magnesium wheels.
I had my Porsche tech upgrade my rear tire size to 315.
Hard to imagine, but such a small change in the rear tire size caused the car to be extremely unstable under acceleration. the Torque twist on the steering was so much that I had to switch back to 305.
Old Jul 25, 2007 | 08:29 AM
atomic80's Avatar
Hey Shashi,
You must have never seen this thread by Fred!
https://www.6speedonline.com/forums/...hlight=warning
Old Jul 25, 2007 | 08:39 AM
PorschePhd's Avatar
Correct, you can not change the ratio that much.
Old Jul 25, 2007 | 09:04 PM
tblackj's Avatar
tblackj has a reputation beyond reputetblackj has a reputation beyond reputetblackj has a reputation beyond reputetblackj has a reputation beyond reputetblackj has a reputation beyond reputetblackj has a reputation beyond reputetblackj has a reputation beyond reputetblackj has a reputation beyond reputetblackj has a reputation beyond reputetblackj has a reputation beyond reputetblackj has a reputation beyond repute
Once again... 315 is the width. It has nothing to do with the heighth of the tire. If you get the correct sidewall height in a 315 wide tire, it will work.
Example:
315/25zr19 is 25.2" diameter
245/35zr19 is 25.8" diameter
As long as they are within 3% of each other, the factory gearing and computer will still work.
Old Jul 25, 2007 | 09:55 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
stock rear height is 26.3". There is no current 315 that would fit the rear when using the stock fronts. If you use the 315/25 then you would need something shorter in front like a 235/30 or 245/30
Old Jul 26, 2007 | 06:42 AM
tblackj's Avatar
That makes sense. I just get frustrated when I hear people just use the width when describing a tire.
r_matt_6
Oct 8, 2015 06:07 PM
gulf gt
Aug 27, 2015 10:27 AM
The Oss
Aug 24, 2015 08:19 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
saline
Aug 19, 2015 12:25 PM
