Flashed guys: What PSI are you boosting?
Old Aug 11, 2007 | 08:24 AM
sharkster's Avatar
Originally Posted by treynor
On 93 octane pump, yes. The upgrades are: Protomotive ECU, turbos, and air filter; EVOMS headers and clutch; Miltek exhaust.
It would be interesting to get your car on a dragstrip and see how much power it's actually making?
You're like me.. you like to run 100 most of the time Even 93 is so much better than 91. It's a shame that we have get such crappy gas out here... These cars need more octane...
Old Aug 11, 2007 | 08:29 AM
treynor's Avatar
treynor has a spectacular aura abouttreynor has a spectacular aura about
Is it my fault that there's a station with 100 octane at the pump 3 miles from where I live? Heck, the price difference @ $3.50 for 91 and $5.20 for 100 octane, isn't even very large.
At my car's power level, air temps seem to make a bigger difference for power than octane. Perhaps that's a sign that it's time to put in better ICs..
Old Aug 11, 2007 | 08:56 AM
PorschePhd's Avatar
What gear are you guys doing this in? Also remember the gauge is not that accurate. However in 5th gear at 2K mashing the throttle in sport mode you should hit 18PSI by 3K RPM. If not then something is amiss. The biggest killer as Ben as mentioned is heat! Keeping in mind I still see these levels and it has average 101 for the last week and a half here with at least 50% humidity.
Old Aug 11, 2007 | 11:21 AM
terrence's Avatar
terrence is a jewel in the roughterrence is a jewel in the roughterrence is a jewel in the rough
You're lucky. 100 octane over here is $8 a gallon.
Old Aug 11, 2007 | 12:35 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
You know what is interesting? I have an Actron scanner that I sometimes use while running the car. The stock IC's keep the IAT's within 13-16 degF in nl driving. It becomes less effective when under spirited driving - IAT's creep over 120F when ambient is 90F+. I think some new IC's would make a big difference in sustaining power under prolonged conditions.
Old Aug 11, 2007 | 04:25 PM
sharkster's Avatar
Yes it is! And it's my fault too... I found one here that sells 110 LEADED only 7 miles from the shop as well
And as for the ICs... no more mods for you You are fast enough heh...
Old Aug 11, 2007 | 04:37 PM
TSP-MIAMI's Avatar
TSP-MIAMI is infamous around these parts
Originally Posted by jamie
I have stage III, with giac flash, FS quiet and FS headers. I only see 15 psi of boost, which I think is low.
Please tell me what mods you have and what boost you are seeing in psi.
Thanks!
Pass by Courtneys shop and put the scanner on for giggles. Maybe some code somewhere not showing up. Also, check all the hoses at intercoolers. DV's maybe.
Theo
Old Aug 12, 2007 | 08:43 PM
sharkster's Avatar
eclou... I usually have the track orientated guys use the ICs for that reason. Temps get really high at the track in summer especially and with sustained sessions it seems to help
Old Aug 12, 2007 | 08:45 PM
treynor's Avatar
I'll try to do some datalogging at the dragstrip this weekend. It the IATs are 30+ degrees above ambient, there's real power to be made with an IC improvement.
Old Aug 13, 2007 | 03:17 PM
sharkster's Avatar
As ever, always being useful That'd be good to do. Unfortunately, I never get out these days (I am still working on your project page too )
Old Aug 13, 2007 | 10:57 PM
golfguy's Avatar
golfguy is infamous around these parts
I use Sunoco 93 exclusively. I have stock dv's. I never see above 15.
Jamie,
sunoco 93 is made with a 10% blend of gasohol. it makes your car run hotter and is less efficient than pure gas. try using shell 91 octane which is 100% gas (for now).
Jamie,
try adding some good octane boost to your car on half a tank of gas. These motors have built in EGT's in the turbine housings that the ECU uses to pull timing if things get too hot. Also, are you at altitude in Ontario?
Eugene, do you think the hotter egt caused by gasohol causes retarded timing?
Old Aug 14, 2007 | 06:39 AM
eclou's Avatar
Originally Posted by golfguy
Jamie,
Hmmm. This is interesting because we have alot of blended fuels down here using ethanol. I never paid attention to it but it is something to consider. I have not found how to read the EGT numbers on my scanner yet. I can get the cat temps easily but that wouldn't if the timing is getting pulled from EGTs.
Old Aug 14, 2007 | 10:47 PM
jerrym's Avatar
jerrym is infamous around these parts
17-18 psi, sometimes falls to 15 psi by redline
How about stock?
Emre@Esmotor
Oct 19, 2015 12:06 PM
whtrabt
Oct 5, 2015 05:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
