Paint chip repair using Langka product
Old Apr 2, 2008 | 07:41 PM
keninirvine's Avatar
keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !
I found this product while researching ways to repair paint chips in my hood (caused by previous owner of course). Has anyone had experience with it?
http://www.langka.com/
It came recommended on another forum, and avoids need to do any spot color sanding of touch up areas.
Old Apr 2, 2008 | 07:57 PM
speedoflight's Avatar
speedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud of
several guys over at m5board have reported great success on it. i haven't tried it myself.
Old Apr 2, 2008 | 08:14 PM
seattle_sun's Avatar
seattle_sun is just really niceseattle_sun is just really niceseattle_sun is just really niceseattle_sun is just really nice
I've used it before and it works ok. Much better results with wet sanding and then polishing, which isn't all that hard to do.
Old Apr 2, 2008 | 09:33 PM
Gcalo's Avatar
Gcalo is a jewel in the roughGcalo is a jewel in the roughGcalo is a jewel in the rough
It is a very good product.
I bought the kit but have not yet myself used it although I have a friend who has done wonders with it on his 360.
It does work.
Take a look at this too. http://online.wsj.com/article_print/...676366607.html
Old Apr 2, 2008 | 09:42 PM
It does work.
Thanks, I had just read that article a half hour ago, and they seem to like Dr. Colorchip better. Since I already purchased the touch-up from dealer, I think I'll try the Langka, although the Dr. Colorchip is same price, but includes their special paint mixed to your color code.
Old Apr 2, 2008 | 09:48 PM
Gcalo's Avatar
Originally Posted by keninirvine
---they seem to like Dr. Colorchip better.
True but Dr. ColorChip can't match all the Ferrari OEM colors!
Don't give up on the Langka though. With a name like that it has to be good!!!
Old Apr 2, 2008 | 10:00 PM
Bach 997's Avatar
Bach 997 is infamous around these parts
Please make sure to update us on the results...hope it works
Old Apr 2, 2008 | 10:04 PM
vrnkc's Avatar
vrnkc is infamous around these parts
Langda Product
I have used this product. Results will not be perfect but at least it fills in the chips and levels out the touch up paint. However, I can still see the original outline of the chips. This is because when a rock hits the paint, it actually "lifts up" the edges of the chip. I also found that it takes quite a bit of rubbing with the "solvent" to finally level out the "paint blob". Be sure that the car is very clean of any dirt , dust, etc. because when you rub on the blob eliminator , you can actually scratch the surrounding paint if it is not real clean. Lots of manual labor overall. One final note, I found that I had to do some areas a couple of times because the touch up paint shrinks. Hope my input helps. Good luck.
Old Apr 2, 2008 | 10:14 PM
Thanks for your input. I understand your point about the edges being raised. I was trying to avoid having to color sand the raised touch-up paint, and the blob remover should do that effectively. I could still do some color sanding to try to smooth out any major edges if necessary.
Old Apr 3, 2008 | 01:06 AM
///MJFDDS's Avatar
///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute
The Meguiars sanding blocks work well. I have had good success with the 2000 grit block. Moving it in one direction (usually toward you) over the touch up paint blob will provide a level smooth surface. It will most definitely work quicker than the solvent. Follow it up with a good compound and polish and you can get a great result
http://www.meguiars.com/?pro-blocks/Sanding-Blocks
Old Apr 3, 2008 | 10:08 AM
gmoney's Avatar
My exeriences exactly.
Old Apr 3, 2008 | 10:39 AM
RickinColorado's Avatar
RickinColorado has much to be proud ofRickinColorado has much to be proud ofRickinColorado has much to be proud ofRickinColorado has much to be proud ofRickinColorado has much to be proud ofRickinColorado has much to be proud ofRickinColorado has much to be proud ofRickinColorado has much to be proud ofRickinColorado has much to be proud of
I tried it many years ago and it was (much) less than perfect. Since then I've used professional paint chip guys. They're cheap (less than $100) and do it everyday for a living, so their skills are well honed.
This is a classic art vs. science exercise and Langa tries to make it into a science - get an "artist".
COBB Tuning
Jan 1, 2025 09:02 AM
007AMV8
Oct 19, 2015 09:55 PM
LiquidElephant
Aug 27, 2015 06:17 PM
gulf gt
Aug 27, 2015 10:27 AM
