Seat Removal
Old Aug 20, 2008 | 09:34 PM
shooterguy's Avatar
shooterguy is infamous around these parts
Seat Removal
Do I need a special tool to remove the bolts for my front seats? Where can I find one?
Old Aug 20, 2008 | 10:04 PM
GTS-R's Avatar
GTS-R is infamous around these parts
You need a torx socket, but I can't recall the size.
Old Aug 20, 2008 | 10:13 PM
NorthVan's Avatar
Changing your seats?
Old Aug 20, 2008 | 10:15 PM
Zuluracerx's Avatar
Zuluracerx has a brilliant futureZuluracerx has a brilliant futureZuluracerx has a brilliant futureZuluracerx has a brilliant futureZuluracerx has a brilliant futureZuluracerx has a brilliant futureZuluracerx has a brilliant futureZuluracerx has a brilliant futureZuluracerx has a brilliant futureZuluracerx has a brilliant futureZuluracerx has a brilliant future
Ha ha...I just went through this BS. Guess what? Try a 3/8" socket with an extension and a good LONG handle (they are tight) ratchet. Believe it or not, the 3/8" fits perfect! I just installed a set of Sparco DTM's in my TT. Party on!
Old Aug 20, 2008 | 10:35 PM
shooterguy's Avatar
I will give it a try. I got a set of porsche sports seats and was going to make a quick upgrade from the standard seats.
Old Aug 20, 2008 | 10:54 PM
GTS-R's Avatar
It is not that hard to swap the seats. Just make sure you slide off the seat bolt covers carefully and use the right torx. The hardest part of the job is moving the stock seats out of the car as they are heavy. There is a good segment showing the install in the DIY section on rennlist for a 996, but it is near identical on a 997.
Old Aug 21, 2008 | 08:37 AM
cl997's Avatar
cl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to behold
When you remove the std seats, does the airbag light go on? if so does the service centre need to reset this?
Old Aug 21, 2008 | 01:34 PM
GTS-R's Avatar
Yes and yes.
away
Sep 4, 2015 12:30 PM
The Oss
Aug 24, 2015 08:19 PM
Jonathan_CH
Aug 24, 2015 11:41 AM
pwdrhound
Aug 23, 2015 07:36 PM
