Oil Pan Sealant Compound
Old Oct 10, 2008 | 08:28 PM
AP 997S's Avatar
AP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud of
Question Oil Pan Sealant Compound
Long story not so short.
Went to change my oil & filter this morning and discovered the oil drain plug 8 mm hex plug was rounded and the 8 mm hex tool would just spin around. Evidently my Porsche dealer service shop over torque the drain plug and ruined it when they were searching for an oil leak early this year. I certainly don't plan to let them touch my car again.
So now I need to remove the pan (13 M6 X 20 torx screws) and remove the drain plug w/ either an easy out or drill it so it falls apart. I can do this while it's on the car but I think it's better dealing w/ the drain plug while the pan is removed. I don't want to get any aluminum chips from the drain plug drilling inside the motor. It's should be a pretty simple task.
No gasket is required but a sealant compound is specified (Porsche #000 043 204 73). I suspect it's just a prema-seal type of sealant (aluminum to aluminum high temperature) but I want to be sure. Does anybody know the details on this Porsche sealant compound or a suggestion on which type I should use?
Thanks for any suggestions or help.
Old Oct 10, 2008 | 10:52 PM
bernie930's Avatar
bernie930 is infamous around these parts
AP,
don't remove the pan, try to hammer in a torx or 12 point bit if you have them (it will not hurt the oil pan), I have done this numerous times (daily pretty much). If you deceide to remove the cover, use a product called The Right Stuff by Permatex (loctite product) which is the same as the factory sealant. Hope this helps
Bernie
MB Euro
Old Oct 11, 2008 | 08:34 AM
AP 997S's Avatar
Originally Posted by bernie930
AP,
Bernie
MB Euro
Thanks for the info.
I try a bit more to remove the plug while it's in the before I remove the entire pan. It's pretty much butchered up now so it might be even tougher.
Old Oct 11, 2008 | 12:05 PM
Gcalo's Avatar
Gcalo is a jewel in the roughGcalo is a jewel in the roughGcalo is a jewel in the rough
Ouch!
I don't envy your dilemma!
Old Oct 11, 2008 | 01:47 PM
Porsche917's Avatar
Porsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to behold
I believe the part number is 000 043 203 73 its Dreibond type 1209 silicone good for up to 250C/482F its a 30ml tube, clear silicone, not the black 5900 stuff.
Old Oct 11, 2008 | 01:56 PM
Porsche917's Avatar
I dont like to have to do things twice.... but if you want to try, permatex clear silicone says its good for up to 450F and resists oil. You could also try hammering a TORX style socket into the rounded out hole and see if that gives you enough grip to turn the plug out.
Old Oct 11, 2008 | 02:46 PM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
Dont remove the pan. If you can't get it out with an oversized allen wrench, just drill and remove.
Old Oct 11, 2008 | 04:09 PM
AP 997S's Avatar
Problem solved . . . Oil drained and filter changed.
My neighbor had a #8 Easy Out that I just hammered into the the rounded out 8 mm hex hole and carefully backed out the drain plug. Pretty simple and I guess a common fix w/ aluminum drain plugs.
Filled up w/ nine (9) quarts of 0-40 Mobil One. Gauge show all bars so I guess it's full. I'll watch it awhile to make sure.
Thanks for all for your suggestions and help.
Old Oct 11, 2008 | 04:11 PM
Gcalo's Avatar
Don't overtighten this time and then find a brass plug with magnet for next oil change.
Old Oct 11, 2008 | 04:16 PM
AP 997S's Avatar
I torqued the new aluminum drain plug to the Porsche spec . . . . 37 ft lbs.
Filter cannister also torque to Porsche Spec . . . . 15 ft lbs.
Old Oct 11, 2008 | 04:32 PM
Gcalo's Avatar
See if you can find a brass plug. It's a bit sturdier.
E55 Bulldog K2
Dec 15, 2015 08:38 PM
bnreed3
Sep 24, 2015 09:04 AM
Wheeler
Sep 22, 2015 08:02 PM
ECS Tuning - BMW
Sep 11, 2015 09:02 AM
