under hard acceleration is it normal for the car to pull to the left?
Old Feb 23, 2009 | 08:00 AM
nugent_crai's Avatar
nugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud of
It happened this morning again... it does it every time i really get on it
Old Feb 23, 2009 | 08:06 AM
GTSilver997's Avatar
GTSilver997 is infamous around these parts
Originally Posted by sammyrusso
why ? (the above about tire rotated)
directional tires with staggered wheel sizes.
Old Feb 23, 2009 | 08:10 AM
jhbrennan's Avatar
Different sizes front and rear.
Old Feb 23, 2009 | 11:54 AM
Cattman's Avatar
Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !
Assuming all things are equal, there is more weight on the left of the car because that's the driver's side (in the U.S.). The weight of your body, could certainly create a left-leaning bias.
Try doing a hard pull with a passenger of your same weight next to you and see if it happens.
In any case, an alignment is a wonderful treat regardless. I always feel like my car drives sooooo much better after an alignment.
CATTMAN
Old Feb 23, 2009 | 11:57 AM
CATTMAN
AH HAHAHAHAH way too funny man, I NEVER thought of that and this is DEFINITELY why there is pull to the left, im 300LBS!!! and I never drive with a passenger! god, you guys are so on top of your came its scary! Im glad I asked!
Old Feb 23, 2009 | 12:03 PM
Exotic Lambo's Avatar
Exotic Lambo is infamous around these parts
They only time this happened to me n the past it was because I had different air pressure in the rear tires. Also one was new and the other one was 70% tread life.
Check the life of the tires and the air pressure.
Cheers!
Old Feb 23, 2009 | 02:15 PM
Cattman's Avatar
Not sure if you are being sarcastic, but if not, glad I could help. I am sure you could get an alignment setting that would correct for that if in fact you are 300 lbs and never have a passenger next to you, it might be a good idea. Might help the tires wear more evenly, too.
It's funny, I recall the guy who does my alignment mentioning to me that on BMW's, the suspension is set up to allow for a 200lb driver. I don't know if that's true or not, but I did notice that on several BMW's the driver's side was about 1/3 inch higher than the passenger side with no one in the car. With a driver on board, that 1/3 ich delta disappeared.
CATTMAN
Old Feb 23, 2009 | 02:42 PM
nah man, I was serious! Thanks Cattman!
Old Feb 23, 2009 | 03:57 PM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
Does it pull when you engine brake from near redline down?
Old Feb 23, 2009 | 04:00 PM
Sercan's Avatar
Sercan has a spectacular aura aboutSercan has a spectacular aura aboutSercan has a spectacular aura about
Depends on how much its pulling, well since cars are rolling mass it's common for some cars to pull because of all of the power and friction. Thats what happens with my quad, so all I do is take some hard turns.
Old Feb 23, 2009 | 04:20 PM
nucjd's Avatar
nucjd has a spectacular aura aboutnucjd has a spectacular aura aboutnucjd has a spectacular aura about
Could be p-factor that causes an airplane to yaw left. J/K
Old Feb 23, 2009 | 05:59 PM
Targa Tim's Avatar
Targa Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond repute
The solution then is to put a 300lbs passenger. I guarantee you that it will not pull to the left. In fact, it will not pull at all... (sorry, no offense, but I couldn't resist...)
Old Feb 23, 2009 | 06:06 PM
or I could just skip lunch and take a big ****
Old Feb 24, 2009 | 06:43 AM
Ian_UK1's Avatar
Ian_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to behold
Im guessing its because I dont have an LSD and under hard acceleration all the power goes to the right rear wheel but the car normally pulls/pushes hard to the left under acceleration.
This absolutely should not happen. Yes, you might get a very occasional slight push one way or the other due to road imperfections but certainly not constantly pulling to the left under acceleration.
Make no mistake, there is something VERY wrong with either the car or tires and this condition is at best dangerous and at worst potentially lethal. Get the car to a dealer ASAP for your own safety.
Old Feb 24, 2009 | 01:11 PM
amenasce's Avatar
amenasce is infamous around these parts
Originally Posted by stevenross
i live in NY, have a C2 Coupe, with summer tires, if i take it out, and its less than 45 deg outside.. if you gun it, the car will pull a bit to the left.. best bet.. either get winter tires, or take it off of the road for the winter..
Steven
Yes. I have a C4S on summer tires and when it is cold in Chicago, my car will also pull to the left. I was thinking it was either due to the tires being too cold or to the terrible Chicago road network..
MAcarbon
Mar 6, 2017 08:16 AM
MAcarbon
Aug 24, 2015 03:26 PM
MAcarbon
Aug 20, 2015 03:02 PM
MAcarbon
Aug 19, 2015 06:22 PM
MAcarbon
Aug 19, 2015 04:52 PM
