under hard acceleration is it normal for the car to pull to the left?
Old Feb 22, 2009 | 07:04 PM
nugent_crai's Avatar
nugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud of
Im guessing its because I dont have an LSD and under hard acceleration all the power goes to the right rear wheel but the car normally pulls/pushes hard to the left under acceleration.
Old Feb 22, 2009 | 07:22 PM
justatoy's Avatar
justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !
I would think that the any imperfections in the roads surface would cause this!
The road may seem flat but the tires will see it differently!
Stacy
Old Feb 22, 2009 | 07:23 PM
2quik's Avatar
2quik is infamous around these parts
could be that you need your tires rotated?
Old Feb 22, 2009 | 07:24 PM
i have 1200 miles on the car, hopefully not yet. It happens almost everytime I accelerate HARD, i feel myself compensating for it pulling to the left
Old Feb 22, 2009 | 07:25 PM
Verde's Avatar
Verde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond repute
That's not been my experience.
stevenross's Avatar
stevenross is infamous around these parts
happened to me...
i live in NY, have a C2 Coupe, with summer tires, if i take it out, and its less than 45 deg outside.. if you gun it, the car will pull a bit to the left.. best bet.. either get winter tires, or take it off of the road for the winter..
Steven
Old Feb 22, 2009 | 07:27 PM
Steven
So its because of not having the LSD?
Old Feb 22, 2009 | 07:32 PM
stevenross's Avatar
forgive the ignorance... whats LSD?
Old Feb 22, 2009 | 07:34 PM
limited slip differential
Old Feb 22, 2009 | 08:06 PM
NorthVan's Avatar
It could be alignment, tire pressure, or as Stacy said the road (crown, grooves, etc).
I didn't have this problem before my LSD.
Old Feb 22, 2009 | 08:19 PM
bugattitech's Avatar
bugattitech is infamous around these parts
Does the car pull when you are not accelerating. I would think that it could need an alignment. Look at your tires do you see uneven wear patterns. Run you hand accross the tread of the tire can you feel feathered edges. You tires should tell you the story with your alignment. Quick fix check your tire pressures. Next have the suspension inspected or have an alignment.
adias's Avatar
adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !
Tires rotated? You do not want to do that on a 911.
Old Feb 22, 2009 | 08:30 PM
NorthVan's Avatar
Common that is easy! With another car of course
Old Feb 22, 2009 | 08:34 PM
DD GT3 RD's Avatar
DD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud of
why ? (the above about tire rotated)
Old Feb 22, 2009 | 09:21 PM
Dave07997S's Avatar
Dave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant future
This isn't a limited slip issue. Remember, the power will go to the one that loses traction without a LSD. However the Brake Biased diffy on the 997 will compensate for this. Also, this will only be an issue if you are breaking the tires loose. If they aren't spinnng the car shouldnt be pulling to either direction. FWD cars will do this as this is called torque steer, but RWD cars don't do this.
Dave
