Issues with wheel shimmy post spacers
Old Jun 4, 2009 | 06:58 AM
hoeferland's Avatar
hoeferland is infamous around these parts
Hi All,
Thank you for all the feedback. I appreciate your help! I'm taking my car into Matrix today and we're going to take everything apart to make it it all came together correctly. As for the spacers, they are brand new H&Rs that we bought from Tire Rack and we did go with the right (longer) lug nuts.
I will let you know what we find!
Carl
Old Jun 4, 2009 | 07:54 PM
hoeferland's Avatar
Follow-up solution
Hi All,
Well, as it turns out the front spacers are probably not going to work. After the spacers are installed their isn't enough of the wheel guide left to center the wheel properly on the hub. As you can see from these photos...
Dang, I really like the stance the front had with the spacers, but we're not seeing how to get the wheel centered on the hub perfectly. If anyone has any ideas that would be great!
Carl
PS I'm currently running a set of Carrera Sports (8.5;11.5) http://www.wheelenhancement.com/inde...lDetail&id=166
Old Jun 4, 2009 | 08:27 PM
Dave07997S's Avatar
Dave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant future
Originally Posted by hoeferland
Hi All,
Carl
The Eibach's are hubcentric...see my post above.
Dave
Old Jun 4, 2009 | 08:36 PM
RT-TURBO's Avatar
RT-TURBO is infamous around these parts
All of the above replies are good info. I'd remove the spacers in front, reinstall the wheels sans spacer properly torqued and see if the problem remains. Then checking the spacers for trueness I'd install one side take a very short ride to see if reoccurs , if not install the other side and repeat the test run. In short try to isolate the cause. Be sure to retorque after 75 miles or so. It's probably something very minor in the install, I like others didn't have any issues with my identicle install. Good luck
Old Jun 4, 2009 | 09:38 PM
NorthVan's Avatar
Hi All,
Carl
Carl, I am running the same spacers on my car, and I have not had any wobbles at all. I agree that there is very little "bite" but they seem OK.
You could probably get away with a wide hubcentric spacer in the front.
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
