Uhhhhh... my car won't start....
Old Jul 7, 2009 | 11:11 AM
///MJFDDS's Avatar
///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute
Like others have said, probably needs a replacement battery. This past Saturday my car started right up after sitting for 12 days straight. Hope you get it resolved soon.
Old Jul 7, 2009 | 11:30 AM
locus's Avatar
locus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond repute
BTW, anyone knows how much OEM battery for 911?
Old Jul 7, 2009 | 11:33 AM
Dave07997S's Avatar
Dave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant future
My car sat for 2.5 mos. without it ever being started and the battery was drained. I took it for an hour drive and have had no issues so far. I also left the car unstarted for 3 weeks and the car started right up. If you get 3-5 years from a bettery that's about the norm.
Dave
Old Jul 7, 2009 | 12:20 PM
heacuva's Avatar
heacuva is infamous around these parts
Originally Posted by DJS
VERY glad to hear you guys think it's nothing. Will get the tender--as I said, my seller offered me one already. Now I'll definitely get it! Tell ya what happens after r-side comes later today.
take ur car to a porsche service and ask them to get a reading of the input output voltages. prolly it ur dynamo (accumulator charging) failing u and hopefully it didnt damage any parts yet. its kinda common in 997s
Old Jul 7, 2009 | 02:41 PM
Mr. B's Avatar
Mr. B is a name known to allMr. B is a name known to allMr. B is a name known to allMr. B is a name known to allMr. B is a name known to allMr. B is a name known to all
+1
Originally Posted by damon@tirerack
Buy a Battery Tender. Problem solved.
+1 on this recommendation.
Mr. B
Old Jul 7, 2009 | 04:13 PM
Taiwanese's Avatar
Taiwanese is infamous around these parts
Did you ever find out what went wrong exactly?
Old Jul 7, 2009 | 05:00 PM
tejoe's Avatar
tejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud of
to Locus: several experienced techs have told me to go with Interstate rather than OEM replacement.
General: my Porsche trickle charger says to NOT use it on sealed batteries.
FWIW: newer Pcars should be locked when not in use; too many electronic things keep running and you cut 2/3 of them when car is locked.
Old Jul 7, 2009 | 05:03 PM
DJS's Avatar
DJS
DJS is infamous around these parts
the verdict from Porsche today
Got it jumped from roadside, started right up, no info mssg stuff, everything fine. Drove it to dealer--turned it off, waited about 20 min's, and when I turned it again, it was a reeeeal slooow ignition turn. Advisor said there's a wire that feeds or comes off the battery that has been a problem on the 997's--and recommends replacing it and battery at ZERO charge (warr.) A tech came over and felt the same way, the battery. Sorry for my lack of technical knowledge and terms... that's all I got so far. Thanks for all replies! This is a great forum. I will tell advisor about recommendations made by you guys.
Old Jul 7, 2009 | 05:04 PM
awcayenne's Avatar
awcayenne is a jewel in the roughawcayenne is a jewel in the roughawcayenne is a jewel in the rough
did you leave your key in? That drains the battery fast. Make sure you pop the hood before the battery completely drains or you have tho go through a lot of work just to get it open.
Old Jul 8, 2009 | 03:48 PM
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
hey guys,
Well, when I bought the 997S, the seller told me that if you don't drive it for a while, it might not start. Well, I didn't drive it for about 8 days... and it won't start. Should I just jump start it? treat it like a normal car? Sigh...
You have to feed the hamster in the front boot, you know!
If the battery is ca 5 years old, its probably at the end of life and needs to be replaced. A battery maintainer may limp you along, but the fundamental problem is likely the battery is at end of life and will not maintain a charge past a few days. A good battery would allow the car to sit for a few weeks and start up again. If not driving for more than a few weeks, THEN a battery maintainer is recommended/needed.
Old Aug 9, 2009 | 08:15 PM
boni's Avatar
boni is infamous around these parts
same here, my 2004 996 turbo died for being in the garage over 10 days. is it ok to charge the battery with regular battery charger by removing the battery terminal? will there be any problem with the key remote control codes or any other system computer codes. any comment? thanks......
Old Aug 10, 2009 | 08:40 AM
afridi's Avatar
afridi is infamous around these parts
If you leave a door unlocked and leave the car to sit it drains teh battery quicker than if you locked it.
MAcarbon
Mar 6, 2017 08:16 AM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
MAcarbon
Aug 19, 2015 06:22 PM
MAcarbon
Aug 19, 2015 04:52 PM
saline
Aug 19, 2015 12:25 PM
