ET40 Offset on 19x8.5 wheel upfront too aggressive?
Old Aug 3, 2009 | 12:29 PM
lakerholic's Avatar
lakerholic is a splendid one to beholdlakerholic is a splendid one to beholdlakerholic is a splendid one to beholdlakerholic is a splendid one to beholdlakerholic is a splendid one to beholdlakerholic is a splendid one to beholdlakerholic is a splendid one to behold
Looking at some wheels that have a verrrry aggressive offset upfront and I don't know if they'll fit my narrow-body 997.
Currently running 19x8, ET57 stock lobster forks, looking at going to 19x8.5 ET40... using wheel enhancement's wheel offset calculator, it looks like this will result in the wheels being 23MM further out, and without help, I don't know if this will result in the wheels stick out past the fender.
Thoughts?
(thanks in advance)
Old Aug 3, 2009 | 02:09 PM
HATTRICK's Avatar
HATTRICK is a glorious beacon of lightHATTRICK is a glorious beacon of lightHATTRICK is a glorious beacon of lightHATTRICK is a glorious beacon of lightHATTRICK is a glorious beacon of lightHATTRICK is a glorious beacon of light
Yeah man, that's a big time punt. Won't look good at all.
Old Aug 3, 2009 | 02:47 PM
lakerholic's Avatar
Man. That's what I figured... LOL. Ok, the search continues....
I need a pair of 19x8.5 Techart Formula (Silver) wheels in 997 NB fitment (I think Techart has ET40 and ET48, and ET48 will look right) if anyone has a good source for these at a decent price, PM me. Used is mint condition is ok too.
Yes, I know the wheels are heavy.
Old Aug 3, 2009 | 03:23 PM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
PM sent.
Old Aug 3, 2009 | 03:27 PM
Dave07997S's Avatar
Dave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant future
You don't want to go beyond 47-48mm...
Dave
Old Aug 3, 2009 | 04:42 PM
Bara's Avatar
Bara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant future
i have the stock gt3 8.5" with the 53mm offset and i would not want them any farther out as they sit pretty flush as is
Old Aug 4, 2009 | 05:57 AM
machina's Avatar
machina has a spectacular aura aboutmachina has a spectacular aura about
I run CCW 9" front with 50 offset and 12" rear with 69 offset.
The key to make these fit is negative camber. You need at least -1 deg front and -2 deg rear to tuck the wheels in properly and prevent tire/fender interference.
I calculated that your 8.5" with 40 offset would project 3.65mm more than my 9" CCW's. So if you can get around -1.5 deg negative camber, you should be fine.
Old Aug 4, 2009 | 07:44 AM
NorthVan's Avatar
I run the 57 mm offset OEM wheels with a 7 mm spacer, so it is like running a 50 mm. I think that you could probably get away with another 5 mm, but you might end up rubbing. The 50 is safe, any thing more may not be.
PenguiN
Nov 12, 2015 05:24 PM
PenguiN
Sep 15, 2015 11:44 AM
ModBargains
Aug 20, 2015 12:28 PM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
