Oil Filter Gasket, Necessary?
Old Sep 7, 2009 | 02:38 PM
RandyP's Avatar
RandyP is infamous around these partsRandyP is infamous around these parts
I've been researching my impending oil change for about two weeks and feel I'm very close to crawling under my Precious to begin the process. However the numb nuts dealer from which I bought my filter did not include a gasket nor did they bother to mention I needed one - I'm clueless when it comes to working with a wrench so I didn't know to ask. I did ask for a drain plug seal which they gave, er sold me. So I'm good to go there.
Is it imperative I replace the filter seal? I'd rather not give them a penny more of my money. I'll keep buying from Suncoast et al.
Old Sep 7, 2009 | 03:22 PM
ntlgnt1's Avatar
ntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud of
Though you may be able to get by with the old, it is best practice to replace it every time you change the oil filter. Tip: Always run your finger with oil around the gasket before you screw it back on and always hand tighten the filter when installing.
Old Sep 7, 2009 | 03:24 PM
IAPorscheDoc's Avatar
IAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond repute
You can get by without the seal. You can go many changes on the same seal, though since it usually comes with the filter, you might as well do it. Are you sure it isn't inside the filter box? Usually them come with the filter together.
Old Sep 7, 2009 | 08:40 PM
Verde's Avatar
Verde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond repute
I strongly recommend you go back and get the seal (it's not in the box?). Though it likely doesn't matter, it's SOP to replace it, if you get a minor leak it's a mess to go in and reseal, and if it's a major leak, well, it's a $100K car.
Since you're doing it at home, make sure the motor is warm when you drain it (wear latex gloves - much safer for lots of reasons), drain for an hour or four if you can, put that thin bead of fresh oil around the seal, and torque the plug (with new washer) and oil filter to spec.
Then underfill your car (just slightly, say 1/2 quart or so) when you refill it. Run it, then let it sit for 20 mins or so (on level ground) and top off to taste!
Old Sep 8, 2009 | 12:29 AM
djantlive's Avatar
it should be part of the oil filter package.
Old Sep 8, 2009 | 06:25 AM
SuncoastParts's Avatar
SuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond repute
Our kits come with the oil filter, rubber seal, and the crush washer (if applicable).
SuncoastParts.com
Your #1 Source for Genuine Porsche Parts and Accessories on the Web!
Visit us at http://www.SuncoastParts.com
Call us at: 877-923-1700
Email us at: Parts@SuncoastParts.com
Follow us to stay connected:
Join Our Newsletter | Facebook
Old Sep 8, 2009 | 06:44 AM
JEllis's Avatar
JEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond repute
My M3 uses a similar rubber seal. I usually change my own oil except when I do not have access to a garage or a lift. A few years ago I was on a coast to coast road trip and I stopped into a place in Missouri to get my oil changed. They forgot to put the rubber seal in which was not a big deal until I got back up to speed on the highway. Once I hit about 80 mph on the highway smoke started billowing out of the back of my car. I pulled over and popped the hood. Most of the oil in the car was all over the engine and burning off the of the headers and exhaust. Long story short, make sure you use all the rubber seals.
Jason
Gunther
Sep 19, 2015 10:22 AM
DLF
Cayenne Turbo
Sep 3, 2015 01:36 PM
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
