Weird electrical issue today.
Old Oct 11, 2009 | 06:01 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Got in my car after visiting Lowe's and got the "unlocking Steering Wheel" message. Took awhile to get the car to start because the steering wheel thing cuts off the ignition for some reason while it's deciding whether it will let you drive off or not. For the life of me I can't imagine what this Warning Light is supposed to protect me from. Anyway, got the car to start after several readjustments to the steering wheel to make sure it was dead straight and the information line in the pod screen, just under the digital speed indicator was four short dashes and nothing else. Stayed like that all the way home. Computer info line was working fine. After I turned if off and let it sit awhile all was back to normal. Odd to say the least as I can't imagine one thing having to do with the other but with all the computers in these cars I suppose program gremlins are to be expected.
Old Oct 11, 2009 | 07:25 PM
JEllis's Avatar
JEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond repute
hmmmm thats strange. Have not seen or heard of this one....
Do you use the steering wheel as leverage when you get out? Do you put a lot of force on it? You might have overcome the lock a little when you hopped out. I use the steering sometimes for leverage and often wonder if I could ever overcome the lock.
Jason
Old Oct 12, 2009 | 02:23 AM
Ian_UK1's Avatar
Ian_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to behold
I had exactly the same issue with my 2005 car. It started with issues with the electronic lock on the steering wheel and then started to produce odd, random electrical gremlins/warnings on the dash. It got gradually worse over several weeks until the car finally wouldn't start.
It also took my local dealer over 2 days to find the problem. They finally traced it to the wiring loom behind the dash. It had been chafing against one of the dash supports and this had finally worn through some of the cables in the loom. These were now randomly shorting-out against the bodywork. The dealer repaired and re-routed the loom and all has been fine since.
Whether this (or something similar) could be the cause of the problem you experienced, I can't say for sure, but the initial symptom is the same. Also as my car is a right-hand drive UK model, it may be the potential for this kind of issue with the loom is totally different. It would possibly be worth asking the dealer to look at this area if you get more issues, however.
Old Oct 12, 2009 | 02:34 AM
rvhpno80's Avatar
rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !
never heard of that, you may need to check with the dealer......
Old Oct 12, 2009 | 02:25 PM
alirob's Avatar
alirob is infamous around these partsalirob is infamous around these parts
Another Weird Electrical? Issue
My 2007 has been making a rumbling sound in the driver's side door. I'm assuming that it is coming from the door radio speaker. My 997 has the standard Porsche sound system. It's strange that I can sometimes hear the sound when I enter the car and before I even put the key in the ignition.
Anyone with a similar problem?
Rob
Old Oct 16, 2009 | 06:05 AM
Dadio's Avatar
Jason
I might but am not aware of it. I'll have to check my exit procedure next time. It's quite possible I'm doing exactly that but I don't think I'm putting much force on it as in using it a lever to push myself up. Odd part was that the wheel wasn't that far from straight when I tried to start it.
alwaysbored786
Apr 19, 2016 05:51 AM
cerbomark
Oct 24, 2015 07:34 AM
powerbeautysoulAM
Carrera GT/918
Aug 31, 2015 02:59 AM
The Oss
Aug 24, 2015 08:19 PM
JMon
Aug 21, 2015 08:20 AM
