Clear Side Marker Installation
Old Oct 30, 2009 | 02:29 AM
Majac4122's Avatar
Majac4122 is infamous around these parts
Question Clear Side Marker Installation
I know I've read on here how to install the clear side markers. I just got mine in and my searches resulted in Cayenne clear side marker installation threads. Can someone help me find the thread for the 997 or post a quick how to?
Old Oct 30, 2009 | 04:38 AM
jjc4scab's Avatar
jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !
Old Oct 30, 2009 | 10:37 AM
stevepow's Avatar
stevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of light
Your owner's manual can be your friend - page 278.
Old Oct 30, 2009 | 10:50 AM
Axxlrod's Avatar
Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !
Simple. Grab the edge of the light closes to the tire and just pull.
Old Oct 30, 2009 | 02:22 PM
EJ-997's Avatar
EJ-997 is infamous around these parts
The manual is the best place to look. I bought my markers from suncoast and included were instructions that stated no tools required. My manual had instructions to use a screwdriver.
Old Oct 30, 2009 | 03:14 PM
oh58driver's Avatar
Awaiting Email Confirmation
oh58driver is infamous around these parts
Look on Suncoast's web site(on the same page you can order the lights.. It is very simple. I just did mine is 5 minutes.
Old Oct 30, 2009 | 03:21 PM
DW997s's Avatar
DW997s is a jewel in the roughDW997s is a jewel in the roughDW997s is a jewel in the rough
Similar subject: Does anyone have experience taking out the fog housing?
I tried to pop it out with the plastic card that came with the car but it isn't coming out. If there are any instructions/visuals available, it will help me out alot.
Old Oct 30, 2009 | 03:56 PM
Scott997's Avatar
Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !
yep, dont get scared nothing will break. It's so easy.
Old Oct 30, 2009 | 04:27 PM
ntlgnt1's Avatar
ntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud of
When I did mine I noticed the stock amber had clear lights and the clear had amber lights. I switched the lights out at the same time so it was clear/clear.
Old Oct 30, 2009 | 04:34 PM
jster's Avatar
jster has much to be proud ofjster has much to be proud ofjster has much to be proud ofjster has much to be proud ofjster has much to be proud ofjster has much to be proud ofjster has much to be proud ofjster has much to be proud of
You may want to check but may be illegal in your state...U.S. typically is an amber side/turn signal either through the bulb or the lens. Once they pull you over they want to write you up for something now matter how good looking your passenger is....
Old Oct 30, 2009 | 04:37 PM
ntlgnt1's Avatar
Very true. I am planning on taking the car to the dealer to have them program it to be euro style turn signals. Fortunately I don't drive much at night, but may opt to put back in the amber lights. I do like the clean look of the clear/clear.
Old Oct 30, 2009 | 04:38 PM
LagunaDallas's Avatar
LagunaDallas is infamous around these parts
I just switched mine out using the Suncoast instructions. Took 5 minutes! Fantastic mod for a whopping $30!
Old Oct 30, 2009 | 04:40 PM
wa1l1in's Avatar
wa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of light
wait wait wait.. he has 997.2
u gotta push something into the hole in the fender liner... then pull. dont just go ripping it.. you need a screwdriver tip in the hole and push the clip then pull off.. my 997.1 u just pull. friends 997.2 we found out about the hole/clip.
Old Oct 30, 2009 | 05:51 PM
thor7000's Avatar
thor7000 is infamous around these parts
Perfect timing for this post...just got back from Florida with a new set of clear's from Suncoast, will be changing them out tomorrow!! Brand new OEM GT3RS front bumper in transit from Suncoast also!!
Old Oct 30, 2009 | 06:30 PM
Majac4122's Avatar
Just installed them. Even on the 997.2's you just pull them....although I followed suncoast's instructions and did it slowly. The only tricky part was to push the pin down to pull out the wires. I kept trying to pry it up and pull. Otherwise, it was fairly easy and that's coming from a guy that doesn't do any work his cars.
