Optimal Shifting Point
Old Apr 3, 2010 | 03:23 PM
Herr C2S's Avatar
Herr C2S is infamous around these parts
Question Optimal Shifting Point
I currently own a 2005 C2S. Perhaps like many of you, I tend to upshift just short of redline when I'm in the mood for spirited acceleration. However, I wonder if for maximum acceleration there is an rpm shift point below redline which at which you should shift so that you enter the next higher gear at its optimum torque. I'm not an engineer, so I apologize if this seems to be an off the wall question.
Old Apr 3, 2010 | 06:05 PM
tejoe's Avatar
tejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud of
If I recall, your torque maxs at about 5000 and then falls a little bit until the HP maxes at around 6500; then both drop appreciably. Ideally, when you upshift in your "spirited acceleration", you want to minimize the RPM drop in the next gear, so you do have to get closer to the redline in the lower gear even though this is above the peak HP/torque.
I'd be interested to know what the RPM shift point is in a PDK car under hard acceleration?
Old Apr 3, 2010 | 06:11 PM
adias's Avatar
adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !
It depends. As I drive it M mode is whatever I want. Typically, 3-4kRPM in regular traffic. 5k-7kRPM in spirited driving.
PDK D Normal mode tends to shift low (2kRPM) even though it is adaptive and it can shift higher. D Sport mod shifts around 3kRPM in normal traffic and higher as you accelerate harder (it is adaptive). Sport Plus shifts at redline.
For the OP: I like to shift 997 manuals in the 3-4kRPM range in normal traffic and do not allow running below 2kRPM. No harm in shifting higher 4-5-6kRPM and the occasional redline.
Old Apr 3, 2010 | 06:29 PM
utkinpol's Avatar
utkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond repute
i guess question was more like what is best drag-strip style start shifting strategy - when upshift on 1st gear, when upshift on 2nd, etc, to achieve max possible result.
I would think probably on 1st and 2nd gear to go up at 5.5-6K rpm area so next gear starts from 4.5K rpm area and after entering 3rd gear keep almost redlining it.
Old Apr 3, 2010 | 06:42 PM
ntlgnt1's Avatar
ntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud of
I didn't write this, but found it an interesting read:
File Type: pdf
Old Apr 3, 2010 | 06:57 PM
adias's Avatar
Drag strip? Not my taste, but turn Sport Plus on and do a launch control and it will shift at redline.
Old Apr 3, 2010 | 09:52 PM
machina's Avatar
machina has a spectacular aura aboutmachina has a spectacular aura about
when you hit the rev-limiter, change gear
Old Apr 3, 2010 | 10:34 PM
Hella-Buggin''s Avatar
Hella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud of
Well, I would think that it would be different depending on the gears in question. The ratio between say 2&3 is different then the ratio between 4&5.
Taking 2nd up to say 6500 will land you at a different spot in 3rd then say taking 4th to 6500 and shifting to 5th.
Old Apr 7, 2010 | 03:41 AM
MishaDesigns's Avatar
Great article!
Originally Posted by ntlgnt1
i didn't write this, but found it an interesting read:
Old Apr 7, 2010 | 04:41 AM
P997S's Avatar
P997S is infamous around these partsP997S is infamous around these parts
Agreed. Great article!!!
Old Apr 7, 2010 | 06:04 AM
neil.schneider's Avatar
neil.schneider has a spectacular aura aboutneil.schneider has a spectacular aura about
I always shift as close to the redline as possible. I would love to know if that is wrong.
Old Apr 7, 2010 | 06:36 AM
P997S's Avatar
read the article - in a 997 s you should shift at redline in every gear except 4th - from 4th to 5th you should shift a few hundred rpms below
READ THE ARTICLE
Old Apr 7, 2010 | 11:48 AM
crazycarlitos's Avatar
crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !
good read
Old Apr 7, 2010 | 03:00 PM
ls03od's Avatar
ls03od is infamous around these parts
Great article, must read.
Texas1
Sep 20, 2015 09:12 AM
albert@velosdesignwerks
Sep 9, 2015 10:33 AM
Sep 9, 2015 10:31 AM
Audi Vendor Classifieds
Sep 9, 2015 10:28 AM
