front suspension knocking sound
Old May 8, 2010 | 04:28 PM
monojohn's Avatar
monojohn is just really nicemonojohn is just really nicemonojohn is just really nicemonojohn is just really nice
I have an 05 C2S and it sounds like my front struts are knocking around when traveling at a low speed. Like in a parking garage. They sort of make a dull knock or rattle. I don't hear them at high speed and the ride seems fine.
Do yours sound like this or am I due for a service visit?
Old May 8, 2010 | 07:38 PM
Stockton's Avatar
Stockton is just really niceStockton is just really niceStockton is just really niceStockton is just really nice
Check you power steering fluid.
Old May 8, 2010 | 08:12 PM
ryem3's Avatar
ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !
Where is it? I hear something that almost feels like the steering rack is loose. Only at low speeds when going into driveways that have a bit of a curb.
Old May 8, 2010 | 08:18 PM
rh888888's Avatar
rh888888 is infamous around these partsrh888888 is infamous around these parts
sounds like the top strut mount. I had the same symptoms and thats what it was. You got to really check mine had very little play.
Old May 8, 2010 | 08:22 PM
ryem3's Avatar
Really?? One more big item and I'll be questioning the "bulletproof" reliability of these things. My factory warranty runs out in a few months...
Old Jul 24, 2010 | 12:40 PM
sphinz's Avatar
sphinz is infamous around these partssphinz is infamous around these parts
I wanted to liven up this thread, because I just experienced the same thing and wanted to confirm that it was the top strut mount.
The car hasn't been driven in roughly 2 weeks, has 9k on the clock. When I turned it on today, and was traveling at low speeds with the wheels turned (i.e. making right turns), I heard the knock on the front right as well. After driving it for a bit, it seemed to have disappeared.
Any thoughts/confirmations?
Old Jul 24, 2010 | 02:53 PM
1BlinkGone's Avatar
1BlinkGone is a name known to all1BlinkGone is a name known to all1BlinkGone is a name known to all1BlinkGone is a name known to all1BlinkGone is a name known to all1BlinkGone is a name known to all
When rubber bushings/grommets age and wear, they shrink a bit, which of course can cause some loose components that weren't loose before. I'd be checking those struts first, then anything underneath the chassis regarding the steering & susp. Give those pieces a tug or a shake... anything loose?
Have your previously hit anything that might contribute to this?
Old Jul 24, 2010 | 03:42 PM
atr911's Avatar
atr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud of
Drop links. Very common but not for newer cars. Hollow clunk?
Possible upper mounts but not likely.
Old Jul 24, 2010 | 10:21 PM
sphinz's Avatar
Haven't hit anything. the car is an 08 with 9k miles - wouldn't the bushings/grommets need a little bit more time/miles than that to age and wear??
I just scheduled an appt. with the dealer for this week, so I guess time will tell. I'll update this thread with their findings.
Old Jul 24, 2010 | 11:26 PM
1BlinkGone's Avatar
With that mileage and more importantly, lack of age, it's probably not that.
Old Jul 26, 2010 | 05:14 AM
cl997's Avatar
cl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to behold
Lucky you dont have Damptronics...
Old Jul 26, 2010 | 08:16 AM
utkinpol's Avatar
utkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond repute
it shold not knock - you may get strut mounts loose, may have doplinks loose, who knows. it`s an '05 car so it got some age now. did you try to stand on the door step and try to rock a car - do you hear anything? do both side rebound in same way?
i would recommend to go to mechanic you trust at least 90%+ with this or you may end up with new suspension.
Old Jul 26, 2010 | 08:18 AM
utkinpol's Avatar
onthing is buletproof. i have killed totally my lexus suspension at 80K miles something as I was drivig it everywhere including fishing on dirt roads, etc. everything dies eventually, especialy links and joints.
in my case shocks itself gave up.
Old Jul 26, 2010 | 10:05 AM
DaveHutchinson's Avatar
DaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond repute
I had a similar knocking sound from the front left, turned out to be a snapped control arm. Worryingly, Porsche didn't find it until their second inspection, first time they gave it back to me, stating there's nothing wrong!
Old Jul 26, 2010 | 08:51 PM
KK Moto's Avatar
KK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud of
Wow, what a great thread. I've having the same issue, however I've had the TPC sway bars put on and assumed it was these.
I have a similar hollow thunk coming from (I think) left front. I've had it to Porsche twice and all they have done is give me a spray can of water resistant lube to deal with the accompanying squeak from the sway bar joints. That has been fixed but the thunk persists?
If I want to do my own physical inspection, what should I look for?
09, 10K miles.
