Check oil level procedure...
Old May 31, 2010 | 08:07 PM
Sub4's Avatar
Sub4 is infamous around these parts
Forgive my ignorance, but I'm having trouble checking the oil level. I think I'm missing a manual, because there is no mention of how to do this. I can find the oil level display using the on board computer, but it simply displays a count down from approximately 28 minutes while animating the oil level graphic. Does it take that long for a reading? What am I doing wrong?
Old May 31, 2010 | 08:13 PM
adias's Avatar
adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !
Check the oil on a level surface with the engine warm. It should take just a few secs (typically 4) to get a reading.
Old May 31, 2010 | 09:01 PM
cbzzoom's Avatar
cbzzoom is infamous around these parts
Best time is when you get gas.
The only problem is you have to remember not to just start the car up right away, which I always seem to forget >:|
Old May 31, 2010 | 09:39 PM
OldGuy's Avatar
OldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond repute
If your car is cold its going to take 5-10 minutes to warm up depending on ambient temp.
Old May 31, 2010 | 09:44 PM
bradyb's Avatar
bradyb is infamous around these parts
I used to get a quick oil level reading automatically in the display every time I turned on the car (in the position before start) but it went away after I changed the battery and now I have to do the full 5-min ordeal to check the oil. Won't work any other way from what I've tried so far.
When I had this feature(?) I checked it a few times against the full procedure and it always showed the same level, so it would be great to get that back.
But here's a completely new idea: Why not attach a long thin piece of stainless steel to the oil filler cap that allows you to check the oil level? I know it's a goofy idea but that would be so cool.
Old May 31, 2010 | 10:21 PM
caly's Avatar
caly is infamous around these parts
left bottom lever push back, scroll up or down for oil, push back to check,cold 10-15 min,warm few seconds(idle only)
Old Jun 1, 2010 | 06:14 AM
Jack667's Avatar
Jack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant future
My 964 has a dipstick but I never use it anymore. The oil level gauge in the dash is very accurate and sensitive. I fill it up based on that gauge. I'm selling that car and buying a 997 and I'm interested in how it's going to work for me -
Old Jun 1, 2010 | 03:04 PM
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
For a 997.2.... Not 28 minutes.. may be 28 seconds... but 28 minutes seems crazy... something wrong with the computation. (if its an earlier car, I cannot comment on those models)
Once the engine is warm (not hot, ie not a case of you just finished some spirited driving at high revs) come to a stop on a horizontal/level surface, and have the computer read it. It may take a few seconds as the system waits for the engine to be at idle long enough for the oil to drain and settle where it expects it to and stabilize.
As said, ideally, you check it after you fill up and restart the engine, before pulling away, or as you pull in before you shut the engine off to add the fuel.
Old Jun 1, 2010 | 03:11 PM
Hella-Buggin''s Avatar
Hella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud of
I have a 997.1 and after getting engine and oil up to temp I park on a level surface and shut off the car. Then turn the key back to the power on position, w/o starting it, and the display will start counting down from 5 minutes. Good time to fill'er up.
I believe, correct me if I'm wrong, that the reading you get when idling is the last reading the computer took.
Old Jun 1, 2010 | 04:00 PM
///MJFDDS's Avatar
///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute
Yeah, Im not understanding how people are checking their oil level while the car is idling. I thought the recommended protocol for checking the oil level is after the oil has come to temp, shut car off, turn key (not to start car), countdown begins from 5 min. mark to display oil level. Is this procedure different in the 997.2?
Old Jun 1, 2010 | 06:59 PM
Fin fever's Avatar
Fin fever is infamous around these parts
c'mon that technology doesn't even exist
Old Jun 1, 2010 | 08:16 PM
wa1l1in's Avatar
wa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of light
drive car till engine is fully warm.... park on level surface and push the stalk and do it.
if you let car sit 5 mins and then restart and check you'll get a higher level reading always... id assume the first above way is most accurate.
Old Jun 1, 2010 | 08:34 PM
John McLane's Avatar
John McLane is a splendid one to beholdJohn McLane is a splendid one to beholdJohn McLane is a splendid one to beholdJohn McLane is a splendid one to beholdJohn McLane is a splendid one to beholdJohn McLane is a splendid one to beholdJohn McLane is a splendid one to behold
Yes. In my old 987s it was with the engine off, ignition on. On the DFI engines, engine on and warm. Takes about 5 minutes idling to accept a read. It will ask from 4 seconds to 1 minute for a read. The full bar means 1 qt, I always add a little bit less than it asks given potential damage to cats.
Old Jun 1, 2010 | 09:35 PM
adias's Avatar
- 997.1 is checked with engine off.
- 997.2 is checked w/ engine idle (different integrated dry sump).
BTW... do multiple readings on different days before adding oil...
Jul 29, 2019 11:13 AM
tkebp1275
Aug 31, 2015 06:35 PM
LiquidElephant
Aug 27, 2015 06:17 PM
The Oss
Aug 24, 2015 08:19 PM
Zero911
Aug 24, 2015 06:51 PM
