997 turbo LED blinker mod to day time lights
Hey Evo, I did the same front end conversion but I can't seem to get the LED blinkers to work. How did you do yours?
I just took a volt meter, figured out what wire was 12v for turn signal and running lights. Pulled those out of the headlight harness wired them to the signals. I cut and made my own harness. the white wires on the signal are actually ground and the black is power. Weird right?
Autolumination.com sells a dual color diode yellow/white. Its their 30smd. I just ordered 2 of those. Got smd harnesa from vleds.com and going to solder it all up
. How is it different vivid? If theres power and ground you just need polarity right correct?
That site has viruses I suggest nobody click on it. Immediate warning from Google Chrome...
The 997TT is full of fun electrically. If you figure it out, awesome, but test it on a 997. We have tried many things.
Yeah, I just noticed that. I have a 997s and recently upgraded to a turbo face. Any advice on how to make my LED blinkers work?
i mean it would be a ton of wiring but u could do a relay setup and run a harness to battery. Try measuring resistance of your stock lights then measure on new and match a resistor up to it? I just know the 2 white wires are ground and the one black is +. What exactly does your car do when u try to hook them up?
i will probably copy off of techart and do a relay setup where dtrs drop to half voltage when signals are on so they can be more visable. Also found a yellow 5w diode that needs minimal heat disapation that i can put in the wedge bulb spot
im excited to get this done
