997.2 brakes
Old Dec 30, 2010 | 05:53 AM
rabkay's Avatar
rabkay is infamous around these parts
997.2 brakes
so does anyone know the actual difference between the brakes on the 997 base and the 997S - besides being red? thanks
Old Dec 30, 2010 | 05:57 AM
MSCHWA3439's Avatar
MSCHWA3439 is infamous around these parts
caliper size huge difference perforamnce wise
Old Dec 30, 2010 | 06:09 AM
911cv's Avatar
911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold
Do both sets have the same number of pistons as well?
Old Dec 30, 2010 | 09:37 AM
tcouture's Avatar
tcouture is a splendid one to beholdtcouture is a splendid one to beholdtcouture is a splendid one to beholdtcouture is a splendid one to beholdtcouture is a splendid one to beholdtcouture is a splendid one to beholdtcouture is a splendid one to behold
Besides the red:
- Both S and non-S are 4 pistons calipers. They do not use the same pads so you have more pad surface on the S model - the S calipers are beefier and can presumable apply more force / dissipate more heat.
- The discs are the same diameter but they are thicker on the S model. Better heat dissipation, may last longer.
- I believe you cannot change the pads without removing the calipers on the non-S brakes. That could be a pain if you track and want to swap pads yourself.
Check out this thread:
https://www.6speedonline.com/forums/...09-2010-a.html
HTH,
T.
Feelgood MD
Mar 24, 2016 09:35 AM
MMK110464
Sep 2, 2015 06:14 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
