Window not going back up after door close
Seems like everything is going wrong on my car at once. Anyway, the window goes down a half inch when you open the door and for some reason, it will not go back up after I close the door now. Anyone know anything regarding this issue? Thanks
This has on occasion happened to me several times too... dealer took care of it. The windows would occasionally not go up fully, but whenever I put the drive selector into D it will go up... weird.
assuming you're car is 2008 and its only 2011... you still under warranty? Even if your out of warranty but only just recently, i'm sure you can ask the dealers to do a in-kind warranty service for you?
My P-dealer in fairfield is top notch in providing warranty work, never once was my request denied. It couldn't hurt to try
If you haven't done this before, a reset is simple. Just close the door (after getting in, that is) and raise the window yourself. Next time you open the door, the window will open to that shallow gap to clear the rubber seal, and when you close the door it will lift properly and remove the gap.
Unless something is broken. Which I'm sure it is because I'm sure you already tried a reset.
Gary
Nope not obvious to me anyway. The car isn't here with me, but I was told even after you get in the car with the key in, the window will not go all the way up. I will try this reset though.
I gave him the same window reference in his battery question.
Tow truck from Porsche fixed this one, so thank you. I had a few reasons to bring it in and I'm not so sure it's the battery now. It may be the starter because at times, the car starts right up.
I just had the same issue with my driver side window. It turned out to be a problem with a hidden microswitch that's located behind the door pull. Once you're in the car, if you slightly move the door pull it may reset the switch and pop the window back up. Or you can manually push the switch once you've found it.
Sep 1, 2015 03:16 PM
