997.2 LED DRL Problem/Question
Old Apr 30, 2011 | 03:53 PM
T33's Avatar
T33
T33 is infamous around these parts
My driver side DRL/Turn Signal looked yellowish compared to the passenger side. Took it to my local Porsche dealer and they ordered the new driver's side drivingl iight assembly and I had it installed today. Unfortunately, the new one seems yellowish still. Now they are speculating that the passenger side is abnormally white and may need to replace it. They say they have to consult Porsche and their Service Manager. Has anyone encountered this problem? Thanks
Old Apr 30, 2011 | 11:21 PM
Alan C.'s Avatar
Alan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond repute
Strange problem. I've not run into that issue. Please post the solution when you get it resolved.
Old May 1, 2011 | 07:04 AM
OKB's Avatar
OKB
OKB is infamous around these parts
dont know what you mean, the chrome is yellow or the light is yellow or the glass is yellow.
Is it the yellow bulbs reflecting
Old May 1, 2011 | 08:55 AM
murox's Avatar
murox has a spectacular aura aboutmurox has a spectacular aura aboutmurox has a spectacular aura about
I'm pretty sure he's referring to the color temperature (kelvin). My DRLs appear to be the same color temperature, but the LED light strip just above the DRLs appear to be a different color temperature. One is more yellow than the other.
Of course, these only illuminate when the headlights are on. Thinking about taking it to my local dealer this week.
Old May 1, 2011 | 10:11 AM
T33's Avatar
T33
it is the LED Strip above the DRLs. Driver's side is more yellow than the passenger's side. If the headlights are not on, it makes the whole DRL look yellower too. Dealer has replace the whole assembly, still the same. Will know Monday what Porsche and Service Manager will say.
Old May 1, 2011 | 12:02 PM
OKB's Avatar
OKB
in that case I would say low voltage on that side. The voltage must be supplied by an external power supply , maybe some part of the headlites ballast. Or maybe further away like the headlits switch or fuse panel or relay, etc. But some voltage drop to that side. Have them check the voltage to that led strip.
Old May 1, 2011 | 02:02 PM
T33's Avatar
T33
That's a good point. I am suspecting that it has something to do with a module for LEDs. Thanks
Old May 1, 2011 | 05:53 PM
vraxinus's Avatar
vraxinus is infamous around these partsvraxinus is infamous around these parts
yes, mine too. but i took to the porsche dealer but the guy said he can't suspect the difference (not smart enough) LOL. going to another dealer to have it check.
Old May 2, 2011 | 02:36 PM
T33's Avatar
T33
No smart enough or don't care enough. Next time you have it check park the car in a shade, it would show more.
Spoke to the dealer today. They said they will order me a set, Left and Right, and go from there. If it still won't match, they'll investigate further into the modules, etc.
Old May 2, 2011 | 10:05 PM
Howie's Avatar
Howie is a splendid one to beholdHowie is a splendid one to beholdHowie is a splendid one to beholdHowie is a splendid one to beholdHowie is a splendid one to beholdHowie is a splendid one to beholdHowie is a splendid one to behold
I have noticed the same thing on my 997.2. One side looks like it has a higher colour temperature than the other. It looks more 'purple-ish tinge' than the other which is more white.
Old May 3, 2011 | 01:17 AM
vraxinus's Avatar
Ok, will do. Let me know the solution to your led. Thanks
Old May 3, 2011 | 04:21 PM
T33's Avatar
T33
No problem, I'll keep you posted.
XLR82XS
Oct 5, 2015 07:02 AM
mxracer
Sep 17, 2015 05:30 AM
ECS Tuning - VW
Sep 11, 2015 01:17 PM
lokmeup
Sep 9, 2015 09:24 PM
ECS Tuning - VW
Sep 9, 2015 12:35 PM
