engine goes bang. 05 097s
Ok. Some bad news.
AOS replaced. And now rear main seal is shot. They're dropping tranny tomorrow to confirm but I have to call porsche na tomorrow to have a chat about this. Not happy at all.
Ouch! RMS is about $2,000 at the dealer. I would assume an Indy will be cheaper.
That really is bad news. If the tranny was already dropped for the other repairs, then most of the labor has already been taken care of and replacing the RMS will be alot cheaper. But if they have to drop the tranny just for the RMS, then the labor costs will be much higher. Keep us posted on what Porsche NA says but I'm thinking they won't do much (I hope my feeling is wrong). Please posts all your costs with this repair to give us an idea of potential future costs on these cars if no additional warranty in place. Sorry to hear the bad news man.....
only in 06-08 with the revised larger bearing. 05 and prior had the smaller bearing and can be extracted "easily" for retrofit. OP states he has an 04 build so IMS wouldnt require teardown.
No help from porsche.
Seems like the AOS failure sucked the rms out. So even though the seal had been changed with new clutch it didn't matter.
I'm out about 1300 at porsche for the aos.
They wanted to charge 1900 for rms but my Indy only is charging about 850. On a flat bed on it's way to Hergesheimer.
+1 When you have the labor done to replace the RMS you're only looking at incremental cost to upgrade the IMS with the LN Engineering kit. It's a no-brainer.
Double ouch . . . $1900 for RMS when they already have the car and done the AOS work is B.S. The LN Eng'ing IMS Kit is certainly the way to go. I've been told that in early 997 motors the IMS can be changed w/o breaking the motor apart. If so it reduces the labor cost significantly.
I've got an early build 2005 (Launch Car #337) so I'm following the thread w/ great interest. I about 23K miles w/ no issues. I'm keeping my fingers crossed.
Keep us posted regarding the Indy work.
Thanks . . . .
Thanks . . . .
