ANOTHER 991 Test - TOP GEAR
Old Jul 1, 2011 | 07:06 AM
dallascajun's Avatar
dallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant future
OK, just found this article online, this time by Top Gear Magazine. This article discusses less of the spec changes and more of the reasoning behind those changes and the related effects on the car. A good read:
Back in February 2011, in South Africa, Top Gear climbed into a car that looked very much like a Porsche 911, but such was the secrecy we can only talk about it now.
A 911, but not as we know it. Under the tape and mesh lights covers and false turbo-look side vents, it's running all-new body and chassis. But then when did a new 911 ever look much different from the old? Not since ever.
It even sounded the same: again, no surprise given its flat-six isn’t vastly modified from what today’s retiring 911s have.
We’ll have the full story in next month’s Top Gear magazine, but for now, here are some of our impressions of our time in Porsche’s prototype 991, only the third new 911 design in the car’s 48 year history. It's going to be formally unveiled at the Frankfurt show in September.
First, the big surprise: it felt less rear-engined. Less 911-ish, more Cayman-like. Because, in a way, it is. Of course, the engine’s where it always was, hanging out the back. But the rear wheels have moved 70mm back to meet it, reducing its leverage over the rest of the car. So the mass of that engine has less see-sawing effect when you go over crests or dips. If those events coincide with a corner, there's less corkscrewing body movement.
The new shell also has its front wheels further forward, and a more sloping windscreen centreline. So it's roomier and more aerodynamic. But the screen pillars are still fairly upright to make the car as easy to see out of as all 911s are, and most other supercars defiantly aren’t.
Another fundamental change: for the sake of fuel economy, the steering is now electrically powered. Potentially dismaying news, given the dishearteningly remote systems used elsewhere, but August Achleitner, boss of the 911 line and our driver for the day, is insistent it will offer less interference on straights but the same feel as the old car in bends. We shall see.
Though the longer wheelbase gives a little more cabin room, the overhangs are shorter, so overall length doesn't rise much. And it's no wider. Still a compact, useable, glassy car. Good.
They moved the wheels by changing the gearbox – the new manual is a version of the current three-shaft PDK box, and this has its driveshaft flanges further back than the old manual. Obviously in converting the PDK to a manual, they won’t have blocked off any of its seven speeds. Prizes for naming any other seven-speed manual? (Trucks and tractors not allowed.)
But the new platform isn’t just about moving the wheelbase relative to the weight, it’s also about actually cutting weight. Aluminium is used for the floor, the main structure front and rear and most of the external panels. The rear wing and inner and outer bodysides are steel and so is the front crash structure. The new shell and other weight improvements shave somewhere between 30-40kg out of a base 911 Carrera.
If they’d left it as all-steel, it would have put on weight, not lost it. Maybe by as much as 60kg heavier than before, because it’s longer and has more kit and its standard wheels have gone up to 19-inch.
Performance numbers aren’t final yet, but in the Porsche way they’ll all be a sliver better than the cars they sell now. For economy the base car drops to a 3.4-litre from a 3.6, but it’s still very slightly more powerful than it was at 350bhp – 20bhp more than a Cayman R’s 3.4 because it has its own cylinder heads and revs higher.
The Carrera S still has a 3.8-litre, but now revving up to 7800 because of new injectors, camshafts and their drive. That means 400bhp.
And economy rises on all. Over recent history Porsche has always managed at least a 10-percent improvement for each new model. The engineers don't shake their heads when you suggest they've done the same this time. That would put the 3.4 Carrera PDK at about 33mpg and roughly 200g/km. That’s ruddy unbelievable for a GT that’ll do 0-60 in the mid-fours.
Style-wise, the full drum-roll debut is at the Frankfurt show in September – to make our prototype resemble 997s the car was well-padded with matte-black plastic wraps to dull the curves, plus bra and pants front and rear. But you can see the curvier line to the top of the rear wings, and the way the rear window sits slightly recessed in the bodywork. Inside the cabin uses lots of Panamera parts, but it doesn’t feel like a saloon in here. Just a sports car with shedloads of buttons for all the optional equipment.
For more, you’ll have to wait for the full story in the next Top Gear magazine (out Wednesday July 13). And then once again, when we actually drive it. But do let us know your initial thoughts in the meantime…
Old Jul 1, 2011 | 10:38 AM
Scoper's Avatar
Scoper has a spectacular aura aboutScoper has a spectacular aura aboutScoper has a spectacular aura about
Thanks for that. Funny but this description makes me want to really know what the bodywork looks like. Sort of feeling deceived by the camo - I was under the impression that the 991 would have very similar styling to the 997, but now I'm starting to think it's going to be distinctly different...
Old Jul 1, 2011 | 12:42 PM
adias's Avatar
adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !
"First, the big surprise: it felt less rear-engined. Less 911-ish..."
Old Jul 1, 2011 | 06:02 PM
thefr7's Avatar
thefr7 has a spectacular aura aboutthefr7 has a spectacular aura about
I'm excited. I know everyone (including me) is fearful of the 991 losing that magical 911 "thing", but trusting Porsche knows what they are doing and may succeed in actually making it better
Old Jul 1, 2011 | 06:19 PM
rvhpno80's Avatar
rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !
idk, what to do...im trusting them as well, let's see....
Old Jul 2, 2011 | 03:49 AM
exponential's Avatar
exponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to behold
That means the 991 will be more balance and better handling so there is nothing to worry about being a better sport cars
Old Jul 5, 2011 | 09:53 AM
Mikli's Avatar
Mikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to behold
thanks, nice find! I love this show, sometime they are so funny.
Old Jul 5, 2011 | 10:27 AM
buck986's Avatar
buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !
It's funny though.
Many people use these terms to describe a cayman but there is no doubt that the majority of 911 owners feel that the cayman is less of a sports car than the 911.
Old Jul 5, 2011 | 12:06 PM
utkinpol's Avatar
utkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond repute
Originally Posted by buckwheat986
It's funny though.
as it was already stated everywhere - all those reviews were co-rides and no one saw real 991 car in person yet, so, we will have to wait 6 more months probably or so until real reviews will sufrace. who knows.
last big move was 993 -> 996 and opinions are still there on both sides of likers and haters.
Old Jul 5, 2011 | 05:48 PM
It's funny though.
If you ask 911 owners, you get comment on one side.
IF you ask the rest of the world, you would probably get the answer that they would love to have well balanced cars in the curves and that is the key to make faster cars and fun to drive.
Don't get me wrong, I love the 911 look but I also happy to see Porsche make them easier to handle and go faster on the track
Old Jul 5, 2011 | 06:10 PM
Howie's Avatar
Howie is a splendid one to beholdHowie is a splendid one to beholdHowie is a splendid one to beholdHowie is a splendid one to beholdHowie is a splendid one to beholdHowie is a splendid one to beholdHowie is a splendid one to behold
Making a sports car more balanced and better handling doesn't make it a car that people will 'love'.
There is something to be said about the intricacies of the human emotion with endearment to 'character flaws', and how that is transferred to inanimate objects like cars in what we call 'character'.
Old Jul 9, 2011 | 06:25 AM
If you want stronger 911s character (happy tail) then the 996 or even the older models will do better than the 997. Everytime Porsche introduce new model they try to make better cars and that's what we get.
Apex Chase
Mar 28, 2016 02:00 PM
Sep 1, 2015 03:16 PM
Fabspeed Motorsport
Aug 26, 2015 11:15 AM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
The Oss
Aug 24, 2015 08:19 PM
