Pls confirm how car should work on MAF disconnect
Old Jul 3, 2011 | 08:25 PM
utkinpol's Avatar
utkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond repute
Hi,
I suddenly got misfires on all cylinders - quite a bummer. I suspect faulty MAF sensor as i was stupid enough to clean my k&n filter and spray a bit of WD40 on it - but looking at real time data it seems to report something reasonable - value of 5-7 at idle, stepping on gas to 2K-3K rpms it goes to 70-80. Is it in right ballpark or too low?
I naturally removed k&n filter now and washed MAF sensor completely, engine ran a bit better after that but still showed CELs. It also sounds quite diferent and still misfres I think. So I want to try to assess possible damage before going to a dealer.
I know on 996 cars typical test was to disconnect MAF sensor completely and it should result in proper operation below 4K rpm. Is it same for 997 cars? I had quite bad misfires and loss of torque below 4K but when I drove home 4K-5K rpm range was sort of OK. not sure what got broken there, just want to confirm how to check if it is MAF sensor to eliminate this cause.
Regards, Paul
Old Jul 3, 2011 | 08:47 PM
cuemaster's Avatar
cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !
that was dumb try maf cleaner on it.
Old Jul 4, 2011 | 10:53 AM
Gibbo205's Avatar
Gibbo205 is a jewel in the roughGibbo205 is a jewel in the roughGibbo205 is a jewel in the rough
Hi there
You can disconnect the MAF in the 997 no problem and it will run a baseline map, you can drive the car just as normal, so give it a try.
PorscheEnthusiast
Nov 13, 2015 02:23 PM
r_matt_6
Oct 8, 2015 06:07 PM
no1joey
Sep 2, 2015 12:32 AM
Aug 21, 2015 06:34 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
