Shift Knob Removal Question
Old Aug 8, 2011 | 12:48 PM
808c2s's Avatar
808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !
Shift **** Removal Question
Hey guys,
I recently decided to change out my 997S shift **** for the Boxster Spyder shift **** with red letterings. I followed the DIY that was posted by bbywu, but for the life of me, the **** just can't be removed! I almost had a "hernia" trying to pull it off, but to no avail.
Any guidance or tip?
TIA.
Old Aug 8, 2011 | 01:02 PM
///MJFDDS's Avatar
///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute
Pull harder!! Seriously...It takes a lot of force to get it off. I had to stand in the back with one foot on either side behind the seats and use my body weight in addition to pulling while positioned in fourth. Just be careful and brace yourself for when it comes free. Don't send yourself through the back window!
Old Aug 8, 2011 | 01:04 PM
jjc4scab's Avatar
jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !
mj is correct....did it on my buddies console change and he almost hit himself in the head when it flew off!! Lots of pulling.....u wont break it..pull harder!
Old Aug 8, 2011 | 01:11 PM
808c2s's Avatar
Thanks guys. Damn...that much harder?!!! Thanks MJ for the tip. Will pull HARDER . Reps for both of ya...hehehe.
Old Aug 8, 2011 | 01:14 PM
///MJFDDS's Avatar
Like jj said, be careful to not smack yourself in the face. And I'm sure you know to unlock the ring that holds the boot in place too. Good luck!
Old Aug 8, 2011 | 01:35 PM
jjc4scab's Avatar
2 square bars approximately a ruler length. one on either side of the shaft just below lip. squeeze together, one hand each side and lift
Old Aug 8, 2011 | 01:41 PM
Brian GTS's Avatar
Brian GTS is infamous around these parts
Yes, as I remember doing it couple years ago, PULL HARDER!!!
Old Aug 8, 2011 | 02:12 PM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
I have heard people put two screw driver shafts along either side. Squeeze together as you pull up. Be careful of the rear view mirror and your face.
Old Aug 8, 2011 | 03:13 PM
jjc4scab's Avatar
although it might be painful, pull hard like u r watching ****
Old Aug 8, 2011 | 03:52 PM
bbywu's Avatar
Originally Posted by 808c2s
Hey guys,
TIA.
Just to make sure we're on the same page.
You've pulled up the tabs.
You've twisted the boot clockwise and felt the "click."
At this point, the **** is released. Pull upward.
If you can't get the **** to pull upward, make sure you have twisted the boot clockwise all the way.
bob
Old Aug 8, 2011 | 03:53 PM
bbywu's Avatar
Truly disturbing, Jim.
Old Aug 8, 2011 | 04:06 PM
808c2s's Avatar
Yup, I did exactly like your DIY. Disconnect the boot tabs, twisted the boot 90 degrees clockwise until I can't turn anymore, and I did feel the click. Actually, you can just turn the collar **** clockwise, and it does the same thing. Stuck like flies to sh*t, this ****. Will try again this weekend.
bob
Old Aug 8, 2011 | 04:09 PM
808c2s's Avatar
Dang, and I just rep'd you .
Old Aug 8, 2011 | 04:13 PM
bbywu's Avatar
Then I believe the other people who have commented are correct. Grab hold, pull upward.
bob
Old Aug 8, 2011 | 04:39 PM
jjc4scab's Avatar
