MY Damn Tire pressure monitor
Old Aug 9, 2011 | 12:23 PM
vegaceo's Avatar
vegaceo is infamous around these parts
To hell with this damn inactive tire pressure monitor...lol
The question has been answered before, so I will not ask how to solve it, I will just ask which person can i take the damn car to so it gets fixed. i tried everything except a battery reset, which does not sound like the best idea!? but I just want a professional to look at the problem and get it done for me ASAP. is anyone in the New Jersey area who know what to do with this and can do it for me. The dealer is out of the question as they will just charge for a diagnostic and fix it in a few seconds anyway.
Thanks for the help
Old Aug 9, 2011 | 01:50 PM
Hella-Buggin''s Avatar
Hella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud of
what's wrong with it? What year car?
my 06 TPMS system died about 6 months ago due to the batteries in the transmitters in each wheel going out.
Old Aug 9, 2011 | 01:55 PM
vegaceo's Avatar
the car is an 07, all service has been done to the car including the 40k service.
The problem is, the TPM is saying inactive after it spends 50 miles trying to learn the Tire pressure. However i can see my tire pressure on the passenger side wheels but not the drivers side.
I have look at old post and tried switching the tire mode from summer to winter and other little tricks; however none work.
please tell me were to take it or what to do
Old Aug 9, 2011 | 02:10 PM
I bet your batteries are dead.
Old Aug 9, 2011 | 02:29 PM
vegaceo's Avatar
do i need to take it in to the dealership? or just take it to like the goodyear tire-shop
Old Aug 9, 2011 | 02:42 PM
911cv's Avatar
911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold
As someone else already pointed out -- it is probably your batteries.
You may also want to play around with your onboard computer to see if it is a control setting. Your onboard computer has some functions relating to TPMS.
For example, I believe (not 100% sure) that you can recalibrate your TPMS from here.
GL.
Old Aug 9, 2011 | 03:04 PM
Scoper's Avatar
Scoper has a spectacular aura aboutScoper has a spectacular aura aboutScoper has a spectacular aura about
It does sound like the sensor batteries are failing. If you want to use the OEM tpms you will have to buy new sensors - you can't replace the batteries IIRC. Try suncoast - it will cost about $125 per I think. U then have to unmount tires, swap sensors out, remount tires and probably rebalance. Dealer could do that part, but so could a tire store.
Old Aug 9, 2011 | 03:25 PM
vegaceo's Avatar
Scooper thank you very much and to all else who helped thank you again
Old Aug 9, 2011 | 04:15 PM
Burg Boxster's Avatar
Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !
if you don't have directional tires, you could switch them side to side to see if it's the sensor that's the issue... just a thought but yes, at 5-6 years old, the batteries could be done.
Good luck
Old Aug 9, 2011 | 06:02 PM
paddyh's Avatar
paddyh is infamous around these parts
Thanks for the help
Tirerack.com has these for a total of $384 for 4 sensors and 4 valves + shipping for my 997 C4S.
Suncoastparts.com has the same for $499.96 + shippping
Old Aug 10, 2011 | 01:33 PM
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
I'm surprised that in this day and age with high capacity capacitors and regenerative electronics that there are no TPMS sensors that can store a charge to report pressures at standstlill for days or weeks as well as use the rotational motion of the wheels (the changes in forces on the sensors as they rotate around) to charge said capacitors and power the sensors.
Old Aug 11, 2011 | 08:56 PM
jakesdad's Avatar
jakesdad is a jewel in the roughjakesdad is a jewel in the roughjakesdad is a jewel in the rough
What are the ramifications of doing nothing and let the batteries just wear down and check the tires on a regular basis.... Does it affect other systems if the sensors go dead?
Old Aug 11, 2011 | 10:22 PM
Scoper's Avatar
No I think it would just be as annoying as heck to have the error message pop up over and over and over... And just in case you are getting a flat - you might not know until your rim starts chewing up the tire on the road
Jul 29, 2019 11:13 AM
RallyBird
Oct 7, 2015 01:20 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
The Oss
Aug 24, 2015 08:19 PM
