ABS/PSM failure on track
Old Sep 6, 2011 | 01:40 PM
dakotaporsche's Avatar
dakotaporsche is infamous around these parts
My track car is a modified 2006 C2S. On a very hot humid day on the track at BIR about half way through a DE run session the ABS and PSM failure lights came on. After turning the car off and restarting the lights went off. This happened three times during the next run sessions. My durametric software gives me an engine fault of "oil pressure switch" and the stability management gives me a "return pump failure" fault. My mechanic is not sure if these faults would cause the failures and maybe it was just the extreme heat. Anyone have any experience with this?
Old Sep 6, 2011 | 02:02 PM
utkinpol's Avatar
utkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond repute
not sure what can either ABS or PSM to do with oil pressure... I had PSM error related to yaw sensor, but never to oil pressures.
Old Sep 6, 2011 | 08:32 PM
BLKonBLK911C4S's Avatar
BLKonBLK911C4S is infamous around these parts
Dis your Yaw sensor issue throw a code?
Old Sep 7, 2011 | 07:15 AM
No, those were the only faults.
Old Sep 7, 2011 | 07:33 AM
utkinpol's Avatar
PSM did, code was related to yaw sensor. when I was on RA1 tires. Not i got NT01 in front and somehow it does not generate any error codes anymore. go figure.
i just turn PSM off on track tobe safe. nobody knows what this damn thing is doing anyway with non-stock tires and non-stock suspension.
PV=nRT.
Sep 9, 2022 06:06 PM
pwdrhound
Sep 13, 2016 10:44 AM
Feelgood MD
Mar 24, 2016 09:35 AM
WearyMicrobe
Dec 10, 2015 04:06 PM
Korntera
Sep 15, 2015 08:20 PM
