Weird Phenomenom with Dectane Front LED's
Old Jun 18, 2012 | 02:52 PM
jabed92694's Avatar
jabed92694 is infamous around these parts
Weird Phenomenon with Dectane Front LED's
So I leave my car parked in the garage and plug it into a Porsche trickle charger that plugs from a wall outlet into the cigarette lighter. I noticed that the front LED's flash on and off every 10 seconds or so when the car is plugged in. It's been going on for about a month. I figured it's something to do with AC/DC and voltage based on the frequency. So today I unplugged it and noticed it randomly started doing the same thing NOT PLUGGED IN!!!
Is my car haunted?!?! Any ideas? Oh and I also have the Dectane module installed if that helps.
Old Jun 18, 2012 | 03:28 PM
dianic's Avatar
dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !
Does it do the same when locked after a few minutes?
The canbus system of the car checks whether the filament bulbs are burnt by passing a little current in the harness. As a result, my converted front leds on my TT "glow" when the engine is turned off, and for a few minutes. Less if I lock the car I believe...
Old Jun 18, 2012 | 03:35 PM
jabed92694's Avatar
Never tried locking it, this was always in the unlocked position. It doesn't glow, it a very slow steady flash...on 10 seconds...off 10 seconds....on 10 seconds...off 10 seconds...and so on...
Old Jun 20, 2012 | 03:44 PM
jabed92694's Avatar
Anyone any ideas?
Old Jun 20, 2012 | 05:49 PM
Ken968's Avatar
Ken968 Is a GOD !Ken968 Is a GOD !Ken968 Is a GOD !Ken968 Is a GOD !Ken968 Is a GOD !Ken968 Is a GOD !Ken968 Is a GOD !Ken968 Is a GOD !Ken968 Is a GOD !Ken968 Is a GOD !Ken968 Is a GOD !
I think this is similar to the problem people had with the LEDs after installing the DRL module from orange tuning and other vendors. Do you have one of these installed?
Ken
Old Jun 20, 2012 | 06:16 PM
jabed92694's Avatar
Ken
Yes I have the Orange-Tuning DRL module installed. Is this a known problem with the modules? I did alot of research (read all the posts) before and never heard of this issue. Can it be fixed? Where are the post of others with the same issue?
Old Jun 20, 2012 | 06:24 PM
Ken968's Avatar
I think 1 member severed the wires and added a quick connect piece to disconnect every time he used the car charger. Another option was a different DRL module that would elimate this. I think most have tried the diode hack to avoid the DRL module all together.
https://www.6speedonline.com/forums/...og-lights.html
I'm not 100% sure and I hope others with 1st hand exp will chime in. I don't have the front LEDs on my car and had been watching the threads closely as I decided if I would add them.
Good luck with getting it resolved.
Ken
Old Jun 20, 2012 | 06:58 PM
808c2s's Avatar
808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !
Yes, there is an issue with the DRL's that are connected with the DRL Module to function like 997.2 DRL. The issue occurs when it's connected to a trickle charger or battery charger. PM TT2911 for more info or check this thread for some initial info (Post #26):
https://www.6speedonline.com/forums/...gh-help-2.html
Old Jun 21, 2012 | 09:09 AM
AP 997S's Avatar
AP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud of
Make sure your 'DRL Module' is connected directly to the battery and not some other 12 volt source. I had the same issue until I changed the +12v line directly to the battery.
Old Jun 21, 2012 | 09:44 AM
jabed92694's Avatar
Thanks!
Old Jun 21, 2012 | 09:45 AM
jabed92694's Avatar
Thanks for the info. I will check.
cadman
Nov 13, 2025 08:57 AM
COBB Tuning
Jan 1, 2025 09:02 AM
Enemy
Nov 10, 2015 08:01 AM
pnoob2
Oct 31, 2015 06:34 PM
