standard audio vs. bose
Old Jun 29, 2005 | 10:12 PM
ajl21080's Avatar
ajl21080 is infamous around these parts
tryin to limit my options, for those that have heard both is the bose that much better than stock
Old Jun 29, 2005 | 10:29 PM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
the bose sucks. save your money and put some aftermarket equipment in there. however, all depends on what you're expecting out of a system. doesn't suit me, but the bose came with the car. it'll get yanked at some point soon.
Old Jun 30, 2005 | 12:32 AM
TheJudge's Avatar
Turn PSM Off
TheJudge is infamous around these parts
I have not heard the standard. However, judging from previous (996) P models with standard audio i would suggest that the Bose system is the only crucial must have no brainer no doubt without a doubt fuggedaboutit option on earth. Come to think of it, floormats are pretty important also.
Your'e not gonna want to go aftermarket and let some amateur tear up your car. IMHO
Old Jun 30, 2005 | 01:29 AM
djantlive's Avatar
i vote for bose, best oem system barring a ls430
Old Jun 30, 2005 | 01:45 AM
msindi's Avatar
Id get the Bose for the reason that with newer MOST equipped Porsches it is hard to go aftermarket...
Old Jun 30, 2005 | 02:04 AM
2thfixr's Avatar
2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold
The MOST system should only include the interface between the headunit/amp/cd changer and nav system. All other connections should be pretty much standard and should allow upgrades. It's relatively easy to add a line level converter to feed a signal to an external amp and additional speakers. As long as the head unit is decent, the rest should be a piece of cake to change out.
Old Jun 30, 2005 | 02:30 AM
TheJudge's Avatar
Turn PSM Off
The head unit is in the PCM. I don't think theres room for a unit.
Old Jun 30, 2005 | 06:29 AM
have you guys heard the bose in a porsche? it is horrible. it's not hard to change the equipment. all the locations are standard sizes. just go to a reputable shop. stay away from best buy and circuit city. bose is overprice junk in our cars. it is not the same bose system you get in lexus, etc... the most connections should cause no problems if you scrap everything.
Old Jun 30, 2005 | 06:36 AM
Gary (Fl)'s Avatar
The Newest "Bling King"
Gary (Fl) is infamous around these parts
Re: standard audio vs. bose
DeputyDog is right it does suck... (I have it) My new Pathfinder's system blose it away....
The question is if your going to keep the OEM system, then go Bose cause the standard is worse then what you get in a base Kia.... If your up for aftermarket and there is plenty... then skip it....
NC 996TT
Mar 23, 2023 06:19 AM
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
bzimpfer
Sep 26, 2015 10:55 PM
