high idle oil pressure.
Old Dec 16, 2012 | 05:43 PM
texas355's Avatar
texas355 has a spectacular aura abouttexas355 has a spectacular aura abouttexas355 has a spectacular aura about
Hey, I noticed my car doing something were. The engine is warm, and idle oil pressure is at 5. Pressure drops as I accelerate to 3 then at 3000 rpms its at 4. Pass 3000 rmps pressure is at 5. Is this normal?
Old Dec 16, 2012 | 07:16 PM
Vancouver-BC's Avatar
Vancouver-BC is a jewel in the roughVancouver-BC is a jewel in the roughVancouver-BC is a jewel in the rough
Yes, this is perfectly normal. The oil pressure in my car (2007 997.1 C2) is around 5 while warming up, once warm is around 1.5-1.7 at idle, and then around 3,000 rpm the pressure will be at ~ 5 and stays there up through the rev range.
Old Dec 16, 2012 | 10:29 PM
AP 997S's Avatar
AP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud of
Pretty much what my 2005 C2S does regarding oil pressure as well.
Old Dec 17, 2012 | 09:04 AM
texas355's Avatar
What I meant was the engine is hot (hwy driving for over an hour). The oil pressure is at 3 at 2000 rpms and 5 at 4000 rpms, which all seems normal. At red lights, from 4000 rpms to idle the pressure drops, which is again normal. Whats abnormal is after it drops to about 3, it goes back up to 5, but the whole time the car is idle. When I start accelerating from idle to 2000 rpms pressure drops from 5 to 3, then goes back up to 5 at 4000 rpms, from 4000 to idle to goes from 5 to 3, then back up to 5 while idle... weird
Old Dec 17, 2012 | 09:44 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
I assume you have a 997.1 because on a 997.2 that s not how mine acts. (and they are different engines).
Old Dec 17, 2012 | 12:18 PM
slicky rick's Avatar
slicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of light
Never thought the electric controlled oil pump made so much difference in our 997.2's
Old Dec 17, 2012 | 12:19 PM
forbes210's Avatar
forbes210 is infamous around these parts
It is weird. Common sense will tell you that when engine fully wormed up, the lower rpms the lower oil pressure so at idle should be the lowest pressure from all rpm range. Very often oil pressure sending units or connectors on it goes bad. You can try to play with it. Its located in the engine compartment on a passenger side pretty deep inside.
Old Dec 17, 2012 | 02:23 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
Hot idle for .1 should be in 1.5 vicinity. Assume that is what you were used to. I would wonder about the gauge.
Old Dec 17, 2012 | 03:22 PM
texas355's Avatar
I couldnt tell if it was still doing it this morning (3 mile commute, not enough time for the engine to warm up), but i'll take a video of it if it does it again.
Old Dec 19, 2012 | 07:21 AM
spiffyjiff's Avatar
spiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud of
sounds like a gauge or sending unit issue. i know NOTHING about elecs so dumb question: when the pressure is low, is there less resistance/volts going thru the system? i.e. maybe it's a low resist/volt issue or something?
Old Dec 24, 2012 | 01:38 AM
SRV-Drum's Avatar
SRV-Drum is infamous around these parts
Same experience with my 2007 C4S
Mine has been doing the same thing (randomly). Have tried to determine a pattern but no luck yet; however, no issues with the car so haven't really worried about it.
Old Dec 25, 2012 | 12:51 AM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
When was the last time you had an oil and filter change? Pay attention to the gauge after the oil change.
Old Dec 25, 2012 | 08:42 AM
Fskof's Avatar
Fskof is a splendid one to beholdFskof is a splendid one to beholdFskof is a splendid one to beholdFskof is a splendid one to beholdFskof is a splendid one to beholdFskof is a splendid one to beholdFskof is a splendid one to behold
What year and engine do you have?
Old Dec 26, 2012 | 10:58 AM
texas355's Avatar
about 2 months or 3000 miles ago.
Old Dec 26, 2012 | 12:15 PM
texas355's Avatar
2008 C2S, M97 i believe.
