Opinions Needed on Engine Rattling Sound
Old Jan 12, 2013 | 03:21 PM
CMOS's Avatar
CMOS is just really niceCMOS is just really niceCMOS is just really niceCMOS is just really nice
I'm getting a rattling sound out of the engine on my 2007 997 C4S w/45,000 miles. I can easily hear it at idle outside the car, don't know what happens under load. I have videos of the sound below.
To me, it sounds kind of like the noise that the tension pulley is making on my wife's 2004 3-series with 130,000 miles. I'm only at 45k, so it seems early for a pulley to be going.
In any case, I welcome any opinions on what this is. I'm pretty sure that it didn't make this nose in the past....
Looking around on youtube, there are a bunch of videos that sound somewhat similar, with hypotheses ranging from a bad lifter, bad pulley, bad flywheel.
Any thoughts?
I made videos of the noise here :
and
Old Jan 12, 2013 | 03:25 PM
spiffyjiff's Avatar
spiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud of
could be a pulley. if i were you, i'd take off the belt and spin them by hand to see if any are loose, binding, rattling, etc.
Old Jan 12, 2013 | 03:26 PM
CMOS's Avatar
It is hard to get the belt off? I installed AWE sport cats and a set of rotors on the car myself - so that's about my skill level at the moment.
Old Jan 12, 2013 | 03:38 PM
spiffyjiff's Avatar
nope not hard at all. here's how to remove the air box:
https://www.6speedonline.com/forums/997/245647-diy-air-filter-change-2005-997-a.html
and here's how to remove the belt:
http://forums.rennlist.com/rennforums/6387369-post22.html
Old Jan 12, 2013 | 03:52 PM
CMOS's Avatar
spiffyjiff,
Thanks for the reply! After you de-tension the belt, how do you know how much tension to put on the belt? Do you just keep track of how many turns of the 24mm nut? Or is the tension not affected by removing the 24mm nut?
-Jim
Old Jan 12, 2013 | 04:54 PM
spiffyjiff's Avatar
the tensioner pulley is on a spring loaded arm. so basically you're applying torque to the bolt in the center of the pulley so that the arm bends down bit so that you can take belt off. when you let go of the wrench it will spring back in place (until you bend it down again to reinstall belt). make sense?
Old Jan 12, 2013 | 04:58 PM
CMOS's Avatar
Fantastic! So you don't have to remove the 24mm bolt to de-tension the belt. You just torque on it to bend against the stpring. That explains why in the rennlist walk through it suggests that the bolt should be turned clockwise. I thought that was strong.
That makes it even easier.
Thanks!
Old Jan 12, 2013 | 07:20 PM
spiffyjiff's Avatar
Thanks!
yep, that's all there is to it. good luck and dont forget to post your success!
Old Jan 12, 2013 | 08:09 PM
drummin4fun's Avatar
drummin4fun is infamous around these partsdrummin4fun is infamous around these parts
+1 to the above... it really does sound like a pulley bearing.
Mini George
Jul 29, 2019 12:20 PM
gulf gt
Aug 27, 2015 10:27 AM
Aug 21, 2015 06:34 AM
Fadi
Aug 21, 2015 03:43 AM
