Strut Replacement Advice
Old Feb 11, 2013 | 06:39 PM
ct997c2's Avatar
ct997c2 is infamous around these parts
Need some advice. I have 05 C2S with 47k miles which I think the struts are going. The car bounces a little when driven on slighty uneven roads without pasm engaged. Is it worth looking into aftermarket replacement or stick with oem?
Thanks guys!
Old Feb 11, 2013 | 06:55 PM
Alan C.'s Avatar
Alan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond repute
You might want to check into a set of Bilstein Damptronics. They are compatible with your PASM system and most likely a lot cheaper than OEM.
Old Feb 11, 2013 | 10:48 PM
sixgun95's Avatar
sixgun95 is infamous around these parts
Is it possible the struts are worn in 47k miles? I would be really surprised if they were.
Old Feb 12, 2013 | 08:00 AM
spiffyjiff's Avatar
spiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud of
agreed, first check if theyre worn or if there is another (bigger) issue. then i would def go with something aftermarket. why not - you're already outlaying the $$, why no get something better than OEM. I have bilstein damps on my PASM 06S. love them on street and track.
Old Feb 13, 2013 | 08:44 PM
babyburner's Avatar
babyburner is infamous around these parts
I have one front and two rear struts with 9k miles on them if you're interested. My front driver had a small bend in it so I'm not selling that one.
Old Feb 16, 2013 | 07:17 PM
spoddle's Avatar
spoddle is a jewel in the roughspoddle is a jewel in the roughspoddle is a jewel in the rough
When I purchased my car it had a bad driver side rear shock which was leaking. I also experienced the bouncy ride you mentioned. I ended up picking up a set of low mileage (2k) OEM shocks from another member for a fraction of the cost of a new replacement. I swapped the suspension myself and haven't had any issues since then. You may want to look on e-bay or put a WTB thread in the FS section.
My car had 59k miles when the shock went on it.
orbelo
Aug 30, 2015 12:26 PM
LiquidElephant
Aug 27, 2015 06:17 PM
qbanchin
Aug 24, 2015 10:31 AM
su_maverick
Aug 21, 2015 07:14 PM
