Defrost panel removal?
Old Feb 14, 2013 | 09:44 AM
Beer brewer's Avatar
Beer brewer is infamous around these parts
Hi All,
Does anyone know how to remove the defrost panels/grates, under the windshield on the dashboard? I am assuming it is as simple as pulling out the trapezoidal speaker cover in the center of the dash and then sliding them out towards the center of the dash, but I want to be sure before I attempt it. I need to get them out so I can stuff a boatload of felt behind them and to the sides...have to cure an obnoxious squeek and rattle...
Thanks all!
Pete
Old Feb 14, 2013 | 11:05 AM
johnnyb2016's Avatar
johnnyb2016 is infamous around these parts
Lever out the centre piece, then lever or pull the trims up the way.
They are located into metal clips in the dash.
Old Feb 14, 2013 | 11:37 AM
bbywu's Avatar
I removed the A pillar trim first, as there is a small metal hook that holds the defroster trim at the base.
Old Feb 14, 2013 | 02:13 PM
Arr - i was hoping I wouldn't have to remove the A pillar trim, as (knowing me) the less I have to fuss with, the better. Can they be removed without takng off the A pillar trim, or is tat a must-do?
Thanks guys!
Pete
NIKAS
Aug 20, 2019 07:53 PM
ant_8u
Apr 10, 2016 11:42 AM
AM v12v
Sep 7, 2015 02:17 PM
Wildcat1212
Sep 7, 2015 11:31 AM
