Battery tender question
Old Feb 21, 2013 | 02:34 PM
doc1911's Avatar
doc1911 is infamous around these parts
I've done a search and not found what I am looking for.
I have a battery tender and know I have to connect the black to a ground but where is the best spot on a 2006 C2S?
Old Feb 21, 2013 | 03:02 PM
GuzziGreg's Avatar
GuzziGreg is a jewel in the roughGuzziGreg is a jewel in the roughGuzziGreg is a jewel in the rough
Do yourself a favor and Buy the cigarette lighter adapter and plug it in there. Easy and works great. Been using it on my 2008 C4s all winter.
Old Feb 21, 2013 | 03:04 PM
vividracing's Avatar
Are you using an alligator type connection?
If you don't feel like digging around to find good charging points it seems that the Porsche (CTEK) charger is the best solution.
The actual CTEK branded one is about half the price of the Porsche OEM one.
http://www.amazon.com/Porsche-Dual-B.../dp/B001684YCK
Old Feb 21, 2013 | 03:09 PM
doc1911's Avatar
Good to know for next time. I leave tomorrow. I have one that I used on my BMW that needs to be connected to the terminals.
Old Feb 21, 2013 | 03:16 PM
Sweeper's Avatar
Sweeper is just really niceSweeper is just really niceSweeper is just really niceSweeper is just really niceSweeper is just really nice
Open frunk access battery under panel under the wind shield.
Old Feb 21, 2013 | 03:24 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
black to neg battery terminal, red to positive terminal of battery .....
Old Feb 21, 2013 | 03:32 PM
doc1911's Avatar
The directions I have for mine (Schumacher SE1-12S) say to put the red/ pos on the positive battery terminal and the black/ neg to a ground, not to the negative terminal. That is what I've done in the past on different cars and it worked great. If I can just go to the negative battery terminal that would be easier.
Old Feb 21, 2013 | 03:40 PM
cerbomark's Avatar
that s how I ve done it forever....
I actual use the pig tail quick connect which came with it and it goes to the two battery terminals. I have a Schumacker too, don t remember which model.
Old Feb 22, 2013 | 12:26 AM
carrera997re's Avatar
carrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant future
I got the porsche one very simple plug into the cig lighter done. Gave up on the b/s connect to battery terminal was a hassel.
Old Sep 17, 2013 | 08:30 AM
soccerTOOLsu's Avatar
soccerTOOLsu is infamous around these parts
Which battery adaptor do you use for your CTEK?
The manuals say not to use any adaptors.
Old Sep 17, 2013 | 09:04 AM
Romysc4s's Avatar
Romysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud of
+1 CTEK.
Mine came with 3 different adaptors. 1) cigarette lighter, 2) alligator clip, 3) pig tail connector to the battery terminal. I use option 3 as it is much shorter reach to the AC outlet and it works great! I understand CTEK is the original manufacturer for the Porsche product and it sells for half the price. They look identical except for the Porsche label.
http://www.amazon.com/s/?ie=UTF8&key...l_5klm3c7gmx_b
Amazon.com: Porsche Dual Mode Battery Maintainer / Charger: Automotive Amazon.com: Porsche Dual Mode Battery Maintainer / Charger: Automotive
Old Sep 17, 2013 | 09:51 AM
wc11's Avatar
wc11 has a spectacular aura aboutwc11 has a spectacular aura about
Passenger footwell has a always live cigarette lighter plug just for this reason.
Old Sep 17, 2013 | 08:22 PM
Domer911's Avatar
Domer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond repute
any exposed steel on the car will do. That's a direct answer to your direct question.
Now, I second, third, and fourth the posts that suggest using the CTEK and using the lighter adapter.
Old Sep 18, 2013 | 12:48 AM
MIKCOB's Avatar
MIKCOB is infamous around these parts
Thumbs up
+1 Agreed..!
Old Sep 18, 2013 | 10:32 AM
Romysc4s's Avatar
