Dead battery - can't open trunk to charge
Old Feb 23, 2013 | 09:35 AM
D-squared's Avatar
D-squared is infamous around these partsD-squared is infamous around these parts
I had my 997 4S on a CTEK battery tender all winter. Went out to start it up to run the oil through and it was stone dead (not sure what happened to the tender!). I tried the manual's method of using a donor battery with the positive post in the fuse box, but it's not working. Ideas?
Old Feb 23, 2013 | 09:43 AM
pvanosta's Avatar
pvanosta is just really nicepvanosta is just really nicepvanosta is just really nicepvanosta is just really nicepvanosta is just really nice
There should be a hook/pull on the passenger side door jam which activates a cable release of the frunk. Best to check your manual to confirm. Good luck!
Old Feb 23, 2013 | 09:44 AM
911cv's Avatar
911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold
There is a wire that's hidden behind the black lining inside the front wheel well on the drivers side. Peel back the lining ( you may need to take some screws out) and shine a flashlight to locate the wire. Once you find it, take a pair of pliers and pull on it...it's very hard to do by hand. This will pop the frunk open.
Old Feb 23, 2013 | 10:35 AM
D-squared's Avatar
Didn't see the passenger side hook and the manual doesn't say anything about that. Going to try the wheel-well wire next. THanks.
Old Feb 23, 2013 | 10:50 AM
D-squared's Avatar
happy ending
Pulled out part of that lining and didn't see any wire, but I tried the official method of hooking up a donor battery to the post in the fuse box yet again and this time instead of trying to use the lever on the side of the driver's seat, I pushed the button on the remote and held it down and the trunk popped open! Lesson learned. Now to get it charged up again.
Old Feb 23, 2013 | 12:53 PM
Fskof's Avatar
Fskof is a splendid one to beholdFskof is a splendid one to beholdFskof is a splendid one to beholdFskof is a splendid one to beholdFskof is a splendid one to beholdFskof is a splendid one to beholdFskof is a splendid one to behold
Here are the directions
File Type: pdf
Old Feb 23, 2013 | 01:56 PM
jhbrennan's Avatar
Don't bother charging...your battery is toast. Time to replace.
Old Feb 25, 2013 | 04:14 PM
D-squared's Avatar
You're right
My smart charger says the battery has an internal short. Good thing it's still under warranty -- replaced it last year.
adnanm3
Nov 22, 2023 02:43 AM
PV=nRT.
Sep 9, 2022 06:06 PM
WheelB
991 Turbo Vendor Classifieds
Jul 23, 2018 09:37 PM
spinecho
Sep 6, 2015 08:35 PM
