TPMS issue
Old May 1, 2013 | 12:46 PM
rvc's Avatar
rvc
rvc is infamous around these parts
TPMS issue
both...flat tire warning and system wouldnt register pressures....if one goes does that mean it affects all tire sensors?
Old May 2, 2013 | 09:54 AM
Alan C.'s Avatar
Alan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond repute
On an '09' Cayman S I had something similar. I'd get a low tire warning, then a flat warning all followed by dashes and no numbers. Mine did this two or three times and it never happened again.
Old May 2, 2013 | 02:06 PM
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
If the batteries have run down and the sensors need replacing, then yes, all 4 would go within some window of time since all have seen similar in service time.
The TPMS sensors are, like batteries, brake pads, wipers, belts, and tires, to be replaced at after certain amounts of time. Probably best to put on a new set when you get 4 new tires mounted every 5+ year interval (at however many tire sets that is for you)
Rguy
Apr 12, 2020 11:11 PM
WheelB
991 Turbo Vendor Classifieds
Jul 23, 2018 09:37 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
B8_RDC
Sep 3, 2015 07:13 PM
WheelB
Sep 3, 2015 10:26 AM
