what is the easiest and cleanest way to drain some oil to get correct level on 997.2
Old Jun 8, 2013 | 03:52 AM
slicky rick's Avatar
slicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of light
opening the drain plug is for sure an option. but it might cause leaks and you know how those things are...if you open too much and drop the plug oil just gushes out. maybe our brothers know of a better way to drain some oil thats not too risky and of course not too messy
Old Jun 8, 2013 | 04:10 AM
slammp's Avatar
slammp is infamous around these parts
Drain plug is only option unless you have a pump that can pull it from the tube. I've done it before with the plug just dont unthread it 100 percent and have an oil pan under it. Not a big deal at all easy peasy
Old Jun 8, 2013 | 06:44 AM
whiskywizard's Avatar
whiskywizard has much to be proud ofwhiskywizard has much to be proud ofwhiskywizard has much to be proud ofwhiskywizard has much to be proud ofwhiskywizard has much to be proud ofwhiskywizard has much to be proud ofwhiskywizard has much to be proud ofwhiskywizard has much to be proud of
You say you're looking for the easiest and cleanest method... That would definitely be an oil extractor pump.
Here's one for $10.
Now you've got a method that is easy, clean and cheap.
Old Jun 8, 2013 | 06:52 AM
slammp's Avatar
That's a really good price
Old Jun 8, 2013 | 07:17 AM
jhbrennan's Avatar
Remove oil filter will usually do it for you. How did it get overfilled?
Old Jun 8, 2013 | 09:17 AM
barncobob's Avatar
barncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the rough
yes remove oilk filter and dump as many times as necessary
Old Jun 8, 2013 | 02:20 PM
997pinoy911's Avatar
997pinoy911 is a jewel in the rough997pinoy911 is a jewel in the rough997pinoy911 is a jewel in the rough997pinoy911 is a jewel in the rough
Fumoto drain valve is your best bet, it does work but I did not like the way it protrudes down taking away from the bottom clearance. It works good for car where drain bolt go In sideways oppose to straight down.
Old Jun 8, 2013 | 09:07 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
Try the pump though my friend stopped using it after a while. Don't bother with the spicket valve as it protrudes---you'll never know what could happen with our cars being low.
For reference, the 997 oil change is so much cleaner and easier than the oil cooled engines. My 83sc has 2 tanks and the gushing pressure is so strong that it often splashes even though I have a big wide oil pan.
Old Jun 9, 2013 | 05:14 AM
alpine-al's Avatar
alpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of light
Originally Posted by jhbrennan
Remove oil filter will usually do it for you...
I know from experience that removing the oil filter on a 997.1 is a good way to remove some oil when slightly overfilled, but I I'm skeptical that it will work on a 997.2 with the oil filter on top of the engine.
Old Jun 9, 2013 | 09:33 AM
Hella-Buggin''s Avatar
Hella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud of
But I believe the filter on the 997.2 is located on the top of the engine. It might not work the same way.
Old Jun 9, 2013 | 09:55 AM
alpine-al's Avatar
I know from experience that removing the oil filter on a 997.1 is a good way to remove some oil when slightly overfilled, but I'm skeptical that it will work on a 997.2 with the oil filter on top of the engine.
I'm glad that you agree with me.
Old Jun 9, 2013 | 10:07 AM
Ha... That's what happens when trying to get a little forum time in while getting the kids breakfast. Somehow I just missed the back half of your post.
Old Jun 9, 2013 | 09:48 PM
cab83_750's Avatar
Talking about funny, I once forgot to put a washer onto the plug. I was able to somehow managed to unscrew the plug, put the washer, tighten the plug, and with very little loss of oil.
The Oss
Aug 24, 2015 08:19 PM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
tscales
Aug 24, 2015 08:23 AM
vbb
Aug 21, 2015 10:17 PM
Lucid Moment
Aug 20, 2015 02:22 PM
