Low oil pressure warning after oil change
Old Jul 18, 2013 | 07:17 AM
PSPorsche's Avatar
PSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond repute
I just changed my oil.
When I started the car, it fired up nicely; the engine sounded smooth as silk.
However I got a red low oil pressure warning on my dash, which I acknowledged, and the warning went away.
There are no leaks at the engine oil filter or the drain plug.
The oil pressure is at 3.5 bar at start-up, and drops to about 3 bar after a few minutes.
Is it normal to to get this warning at the first start-up after an oil change? (Note that I did pour some new oil into the oil filter canister before I screwed it back into place).
Also, my 997.1 S requires 9 quarts, per the owner's manual. I initially had 8 quarts in there. The reading was within range even with the 8 quarts, but could this have triggered the warning? Of course, I added more oil as required to bring the reading up to the top mark.
Anyone experience this before?
Old Jul 18, 2013 | 08:31 AM
carrera997re's Avatar
carrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant future
I believe its normal. I think it takes a few seconds for it to cycle the oil around the engine. But i could be wrong.
Old Jul 18, 2013 | 09:00 AM
GuzziGreg's Avatar
GuzziGreg is a jewel in the roughGuzziGreg is a jewel in the roughGuzziGreg is a jewel in the rough
I always put oil in the oil filter cup, helps avoid this. On cars with a canister oil filter I fill the oil filter up also.
Old Jul 18, 2013 | 11:01 AM
PSPorsche's Avatar
thanks, guys. I suspected it was normal, but just wanted to double check.
GuzziGreg, I did fill the canister with oil, but not all the way to the top. How much oil do you recommend putting into the canister?
Old Jul 18, 2013 | 11:43 AM
GuzziGreg's Avatar
Yeah it sounds like you did it right. You can't put much in. If the light went out you are good to go. This does always happen to my 2012 jeep which has the filter on the top of the motor so you can not put the oil in.
Old Jul 18, 2013 | 12:57 PM
ecostellodo's Avatar
ecostellodo is infamous around these parts
Normal for the light to go on until the oil pressure builds up.
Old Jul 18, 2013 | 03:36 PM
AllForTheCash's Avatar
AllForTheCash is infamous around these parts
+1..I do the same or in other cars fill the oil filter with oil before I screw it on. It takes time to build up in there.
Jul 29, 2019 11:13 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
The Oss
Aug 24, 2015 08:19 PM
