Water Pump Longetivity
Old Jan 23, 2015 | 12:30 PM
  #46
Buddhamonk's Avatar
Buddhamonk has a spectacular aura aboutBuddhamonk has a spectacular aura aboutBuddhamonk has a spectacular aura about
Originally Posted by ksdprasad
mine replaced today, mileage is 77350. My local mechanic did the replacement along with spark plugs for $400
That's super cheap. Pump itself is $270 and plugs are $105 and that's without labor
Old Jan 23, 2015 | 12:42 PM
  #47
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
Agree. Too bad I don't have access to his mechanic.
Old Jan 23, 2015 | 12:56 PM
  #48
Buddhamonk's Avatar
I wonder if his mechanic did it for free because porsche antifreeze is $35-40 a gallon. For $400 that leaves nothing for labor...
I'd check to make sure he actually did any work... =)
Old Jan 23, 2015 | 12:59 PM
  #49
cab83_750's Avatar
FYI, when I replaced mine, I just added iirc less than 1 gallon of Porsche antifreeze. I bet he did not flush the entire coolant system.
Old Jan 23, 2015 | 01:04 PM
  #50
Buddhamonk's Avatar
did you dilute it 50/50 with distilled water?
Old Jan 23, 2015 | 01:29 PM
  #51
cab83_750's Avatar
Yes I did.
Old Jan 23, 2015 | 01:31 PM
  #52
cab83_750's Avatar
And unless someone tells me otherwise, I plan a full flush at 100K even though the coolant is supposed to be life-time.
Old Jan 23, 2015 | 02:22 PM
  #53
Buddhamonk's Avatar
I saw your earlier post. I plan on changing just the water pump (not the thermostat). Would I still have to remove the exhaust components (cats and mufflers)? I don't see how they get in the way of the water pump...
Old Jan 23, 2015 | 02:29 PM
  #54
cab83_750's Avatar
Yes, I had to remove the cat/exhaust. I'm unsure why others didn't have to but my layout required the removal of the cats/exhaust. Btw, mine is a C4s just in case people wondered.
Removal was ez-pz so don't let that stop you. Just apply anti-seize compound on the exhaust nuts and bolts for subsequent removal and installation.
Old Jan 23, 2015 | 03:12 PM
  #55
ksdprasad's Avatar
ksdprasad is infamous around these parts
yes, that is just labour, i supplied the parts. he did oil change as well in that(i supplied filter and oil).
Old Jan 23, 2015 | 03:56 PM
  #56
Buddhamonk's Avatar
I've done my muffler and cat more times than I can count. I'm just lazy =) maybe the C2S doesn't require removal
Old Jan 23, 2015 | 04:38 PM
  #57
cab83_750's Avatar
Hehehe. We are all lazy by nature. We are just dictated by our disposable income AND how cheap we are. I save every $ that I would be giving to the mechanic and invest or reward myself with it.
I also treat working on cars as "stretching exercises" and keeping me away from being a home wrecker. Jk
pwdrhound
Sep 13, 2016 10:44 AM
proTUNING Freaks
Oct 13, 2015 08:12 PM
Wheeler
Sep 22, 2015 08:02 PM
carbonjim996TT
Sep 20, 2015 08:14 AM
