Replacement Key Shell
Old Sep 19, 2013 | 09:31 PM
  #31
PSPorsche's Avatar
PSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond repute
Awww man! I just ordered this from eBay, but I ordered the three button instead of the two button that I needed.
Old Sep 20, 2013 | 09:02 AM
  #32
D.Kinsey's Avatar
D.Kinsey is infamous around these parts
Originally Posted by myw
Did the car start with the new key?! From what I am reading you should be able to lock/unlock the car/frunk but the car shouldn't start (transponder chip not moved over)
Dohhhh!!!
Old Sep 20, 2013 | 09:05 AM
  #33
jhbrennan's Avatar
Originally Posted by D.Kinsey
Dohhhh!!!
Is that a "yes" or a "no"? If "yes", any difficulty moving the transponder chip?
Old Sep 20, 2013 | 07:12 PM
  #34
D.Kinsey's Avatar
Car wouldnt start w/o the chip....No real problem getting it out. Like has been said, just loosen it up around the edges with an x-acto blade or single sided razor blade. That actually worked better for me and chipped away the outer case holding the chip in with a small straight blade screwdriver until it fell out. 5 minutes maybe
Old Sep 23, 2013 | 01:38 PM
  #35
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
Ok, so you replace the shell, by putting the old electronics into the new shell.
You also cut out the old transponder RFID chip from the old key plastic and put it into the new key fob plastic.
How do you attach the transponder? Snap in? Glue (what type)?
Old Sep 23, 2013 | 01:46 PM
  #36
myw's Avatar
myw
myw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to behold
you are correct. the transponder has no tabs or clips to keep it into place. it should fit pretty snuggly in the 'transponder coffin'
i used 2 drops of white glue and let dry overnight. itll more then do the trick.
Old Sep 23, 2013 | 02:17 PM
  #37
fjr_wertheimber's Avatar
fjr_wertheimber has a spectacular aura aboutfjr_wertheimber has a spectacular aura about
The three button remote works just fine, even if you only need the two button remote. You'll just have one button that does nothing.
Old Sep 23, 2013 | 04:41 PM
  #38
slicky rick's Avatar
slicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of light
That is true but now you would know its not oem. Wy would you have a 3 button key for a coupe? Im sure its a bit frustrating. You want something nice and end up with somehtign wrong because of personal error
  #39
Its cheap anywyas just order the right one and ask if you can return the wrong one to the supplier
Old Sep 23, 2013 | 07:47 PM
  #40
Its no less OEM than the fact that you're using a key that wasn't originally created for that year.
Old Sep 24, 2013 | 09:45 AM
  #41
myw's Avatar
myw
you dont need this do you minok? you have the 997.2 key no? to remove the rfid chip from the 997.2 key is super easy.
Old Sep 24, 2013 | 11:29 AM
  #42
For the 997.2 the chip just falls off! No need for any scraping whatsoever
Old Sep 26, 2013 | 08:38 AM
  #43
PSPorsche's Avatar
Does anyone know how to pull out the original key-blade and swap it with the blank on the new remote?
Old Sep 26, 2013 | 08:46 AM
  #44
PSPorsche's Avatar
Never mind, I answered my own question. Use a small flat head screwdriver (like the kind for eye-glasses repair), insert it at the base of the key-blade, and pry downward towards the key blade, while pulling back the spring loaded lock mechanism. The blade slides down and out; turn the blade slightly to the right, to avoid damaging the lock mechanism, as it comes out.
Old Sep 26, 2013 | 01:42 PM
  #45
Minok's Avatar
My 997.2 keys are fine.. I just wanted to know what the process was for the day I do manage to mangle or wash a key and have to replace the housing.
