997.1 can you remove oil filter without dumping oil?
Old Sep 25, 2013 | 05:12 PM
floatingkiwi's Avatar
floatingkiwi is infamous around these parts
Hi Folks
Have been seeing a few carbon deposits in the filter and would like to do a few very low mileage filter changes without dumping the oil as it is fresh. Will much come out with the filter apart from what is in the housing?
Old Sep 26, 2013 | 08:03 AM
spiffyjiff's Avatar
spiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud of
logic tells me no. (but i've been wrong many times before.) in any case, obviously not nearly as much as when you dump the pan but i say just try it and see - have a bucket ready and make note of how much comes out so you know how much to add back.
Old Sep 26, 2013 | 12:43 PM
mattyf's Avatar
mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !
I believe you can. There are some threads on oil overfilling that suggest removing the filter as a way to take out a little bit of excess.
Old Sep 26, 2013 | 01:24 PM
AP 997S's Avatar
AP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud of
You can remove the filter canister only just lose the oil it contains. I might suggest waiting until all you oil has settled (ie. cold motor) at it lowest point.
Old Oct 9, 2013 | 02:19 PM
Yes, I just removed it. Very minimal loss of oil, 100-200ml. Easy to do if necessary.
Old Oct 10, 2013 | 08:51 AM
Derek's Avatar
Derek is infamous around these partsDerek is infamous around these partsDerek is infamous around these partsDerek is infamous around these parts
Must have a check vavle somewhere.
Old Oct 10, 2013 | 09:33 AM
italdream's Avatar
italdream is infamous around these parts
Hi Folks
You can. When I had my PPI, I asked the Porsche dealership to take out the oil filter and send me a picture. They did it without having to refill the oil.
mikerosi
Dec 6, 2018 06:23 PM
away
Sep 4, 2015 12:30 PM
LiquidElephant
Aug 27, 2015 06:17 PM
The Oss
Aug 24, 2015 08:19 PM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
